what gen engine?
i used std cams in mine and got 240rwkw so you dont actually need cams but if you want more midrange id go with something around 256deg 9.5mm lift.
you may find 264s to be to big for what you want, but it depends if you want to go big later and just buy big cams now.
as for springs, i would put a set in if you want to run decent boost through it as mine started bouncing at 7500 with 19psi. (gen3)
linden
edit: just clean the ports up in a gen3 but if its gen2 you may want to get them puttied and ported for better flow as the stockers are fairly average in design.
