Results 1 to 12 of 12
Thread: MS85 RA23 Corona struts
    Default MS85 RA23 Corona struts
    Ive done a search and have had no luck
    Ive found an MS85 crown a mate pushed into a gully on his farm
    I want a 5 stud pattern and am wondering if I can use the hubs and calipers on my XT130 struts in my RA23 ?
    Default Re: MS85 RA23 Corona struts
    not directly
    the only 5 stud hub that will bolt on to the corona or celica hub is the MS65
    i do recall someone modifying a ms85 hub to suit try searching for it
    Quote Originally Posted by rob
    not directly
    They bolted on
    Saying that I haven't driven on then though
    http://www.toymods.net/forums/showth...highlight=ms85
    This was all I got with the search
    Forum Sponsor Conversion King
    Dec 2006
    as in the ms65 hub bolts on the celica strut.
    So its all good then ?
    you do know the difference between a 6 and an 8 dont u?
    As has been said MS85 hubs can be modified to work (machine to suit other bearings, as a note the conversion bearings are significantly / lots more expensive). Heck I even did a document up showing what had to be done...
    MS65 is the bolt on way to go
    No
    Thanks mate thats what I was after where is the doc?
    Quote Originally Posted by badboybubby
    Btw the thread this was listed in was titled (Great engrish in the title eh bah)
    "Guide: Using Modifying MS85 hubs to fit MA61 etc"
    And came up as the 7th search response when I searched for "MS85 hubs" (To help you improve your searching skills in the future ).
    The pdf should still be
    PDF HERE <CLICK>
    As it says it is just a guide, check it all yourself before you make it happen
    Also if someone wants to add it to the techdocs by all means that would be good (I don't rate that free hosting all that much...)
    Anyone got some MS65's ?
    good luck
    Black Betty >HERE!<
    (\__/)
    Im sure people have them, but I doubt they want to part with them
  1. Differences between RA23 and 70's corona
    By sam_ in forum Tech and Conversions
    Last Post: 08-10-2006, 04:15 PM
  2. Corona Sumitomo brakes and struts??
    By Snyper in forum Tech and Conversions
    Last Post: 09-09-2006, 06:17 PM
  3. XT130/RT132 struts for RA23
    By RA23 in forum Tech and Conversions
    Last Post: 21-06-2006, 10:37 PM
