Results 16 to 26 of 26
Thread: Quick Question: 1JZ and 2JZ flywheel bolts the same?
    Default Re: Quick Question: 1JZ and 2JZ flywheel bolts the same?
    Not sure if they would be long enough though Norbie. They are probably the same length as the 5speed ones.
    I can measure then up when I get them on saturday/monday if you like. I have a set of bolts from a 1JZ/Flexplate to compare them too aswell if thats of any interest to anyone.
    Malicious
    Junior Member Backyard Mechanic manny's Avatar
    Pic of OEM bolts attached for comparison
    GSE20 IS250 - daily
    Infact, im currently thinking that the 2JZGE and 1JZGTE flywheels are the same
    If 1JZGTE = R154 then clutch is 240mm, no?
    Whereas 2JZGE = W58 with 225mm clutch. I could be wrong though....
    Same diameter clutches though, 240mm. 7M is a 240mm clutch as well. Same spline diameter too. But from what has been posted in the other thread they dont bolt up.
    Also, the ARP bolts are of the length of the R154 bolts.
    GTE and GE the same diameter in 7M? I'm sure someone told me I couldnt use a GTE flywheel with a W58 for some reason. Therefore I assumed the GE flywheels were the same diameter as 5M jobs. Learn something new every day
    Edit - Interestingly I also just pulled a 225mm clutch out of my lexus and replaced it with a 240mm. I wonder what the 225mm job was meant for? It was (obviously) a JZ stud pattern...
    In case it's not common knowledge, 1JZ-GTE/R154 and 7M-GTE/R154 pressure plates and clutch discs are interchangeable despite the different flywheels.
    GSE20 IS250 - daily
    Turboholic Grease Monkey VeeP's Avatar
    ok uhhh. . . .
    im in the process of ordering arp bolts for my 1jz. . .apparently they are similar to the BA falcon ones?!?!
    anyhow. . . im a bit confused - so the 1jz bolts are definetly exactly the same as 4age bolts?
    '88 Soarer GT-L
    '90 Supra Aerotop
    Parts Bitch 1st year Apprentice FIL's Avatar
    I've heard something similar to you VP, re the ford connection...... Which would work out well for us toyota types....
    Junior Member Backyard Mechanic gwilmarlio's Avatar
    ok jsut pulling this one back up
    ill be needing some soon
    1990 JZA70 R 12.959sec at 112.78 mph Kwinana Motorplex
    1J torsen smashing machine
    TR44 Highflow single (366whp at 17psi)
    1988 GA70 SOLD and will be missed
    Yes, im installing 4AGE ARP bolts on my 2JZ.\
    Only the W58/R154 bolts though, V160 is different
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. Quick Q - 2JZ / 1JZ Valve Cover Gasket
    By AndyTTR in forum Tech and Conversions
    Last Post: 30-09-2006, 11:10 AM
  5. 1jz vs 2jz heads
