You sure you are on TDC???? You can always undo the spark plug and slowly turn the engine with a screw driver in place of the spark plug against the top of the piston. Get someone to spin the crank clockwise till just before the piston starts to drop back down again. Hence TDC... Now look at your crank timing marks and your Cam timing marks. They should all line up??? Good luck... I am in the process of redoing my cam timing as i missed it by one tooth....
