Results 16 to 23 of 23
Thread: quick fix of cracked top tank in radiator
    Default Re: quick fix of cracked top tank in radiator
    Quote Originally Posted by Mr DOHC
    u cant get top tanks for JZX81 cores, they are 5mm wider than cressy ones
    What about getting someone to make up an alloy top tank The core is alloy so you can get it welded on!
    I saw the same done on an Aristo at importbitz once when I was there
    Tasmania
    Just use the MX83 radiator, mine is running the hydraulic fan with the standard radiator as I had the same problem. It bolts on up top and then just some extra tabs for the bottom. It's not perfect but better than what you're suggesting IMO.
    Rich
    the standard MX83 radiator doesn't have the hydraulic fan temp sensor bung in the bottom tank the JZX81 uses. The JZX81 radiator with stuffed top tank is 5mm thinner at the tank and the core than the reco'd mx83 radiator I have here
    Excited Member Grease Monkey thomasbl's Avatar
    vic
    Could you go fibreglass? Or one of those co-extruded epoxy polymers like knead it etc should hold up to temps better than araldite. Just make sure it is grease free and i would recommend using gloves when you work with it, the polymer stuff is hard to get off fingers and if you have greasy skin it wont bond as well. Good luck mate.
    I used 24 hour araldyte for months, it went soft after a little while but still barely leaked, so i agree with others it will do fine, just let it go off for the reccomended time if not a bit longer, as i said it may go a little soft from the hot water but it wont let go.
    1uz 4wd Hilux Grease Monkey Dust's Avatar
    The one on our celica cracked, I had a mate weld an alloy top tank on it and never had a problem. cost me a carton of jim beam cans
    the rad shop down the road from me is putting on a brand new top tank for me, minor mods, but new
    The boobs are back
    could you let us know what top tank they end up using?
    I'd like to get my spare JZX81 radiator reco'd
    Jason
  1. Another (easy) AE86 twin core radiator option
    By parrot in forum Tech and Conversions
    Last Post: 25-09-2007, 12:59 PM
  2. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
  3. External radiator header tank
    Last Post: 12-10-2005, 11:52 AM
