Results 1 to 15 of 23
Thread: quick fix of cracked top tank in radiator
    Default quick fix of cracked top tank in radiator
    i have a crackjed top tank, is there a way to fix it, i.e. clean it perfectly and use a resin to block it
    The boobs are back
    Default Re: quick fix of cracked top tank in radiator
    for temporary?
    clean very well, grind surface clean and degrease thoroughly...
    then get epoxy resin/araldite and chux superwipes or similar
    higher temp resin will last longer.
    temporary = 1 week, till jambo is over
    The boobs are back
    and run 7psi cap?
    Western Aus
    quicksteel.
    but even then, your pushing it.
    Elmo.
    i dunno.. with 5 min araldite and chuck superwipes, i had a top tank (and cover on head) last for about a year
    victoria
    cant you bronze it?
    Western Aus
    plastic tanks.
    Stu's idea sounds like a winner then, but you have to make sure the tank is empty, and dead cold, and makes sure its set rock hard before you start it.
    Elmo.
    jetpilot Automotive Encyclopaedia 1JZ.747's Avatar
    why not just get a 2nd hand cressida one to get you through mate. the top bolt holes for ht fan are fine, there arent any ont he botom just put some rubber aorund themso they dotn rub through.
    you have seen the result of leaked coolant under the tyres before. not worht the risk
    8.3 et PB 169 MPH PB
    Quote Originally Posted by 1JZ.747
    whats the result of leaked coolant under the tyres?
    Significantly shortened cars.
    ask rodi, he fucked his car at the strip last week
    its just that i'm significantly running out of time
    The boobs are back
    Quote Originally Posted by Mr DOHC
    haha yeah i follow....
    takes 10mins to pull the rad from the cressy, drop it at your local RAD shop, top tank will average at about $150 to replace, and you will have it back the same day usually!,
    blake
    Modify is my middle name Grease Monkey Darola's Avatar
    Hey all, a quick easy fix is the araldite glue, put it on good and thick and heaps around the crack.... if dryed and done right will hold for a good time... or you can go to a auto shop and get radiator/petrol tank repair stuff... looks like kneadit but flat and u rub it into a ball then spread onto... very good stuff when usesd correctly
    hope that helps
    Ed
    Eddie 0433 85 69 66
    u cant get top tanks for JZX81 cores, they are 5mm wider than cressy ones
    The boobs are back
  1. Another (easy) AE86 twin core radiator option
    Last Post: 25-09-2007, 12:59 PM
  2. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
  3. External radiator header tank
    Last Post: 12-10-2005, 11:52 AM
