Results 1 to 5 of 5
Thread: Hilux calipers
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    Default Hilux calipers
    Have just purchased, or got my dad to pick up my hilux calipers for the pug/hilux/corona conversion, now they're both labelled, a left and a right, but they both look identical to me, thinking they're both RHS...
    If they were left and right, then the bleed nipple on one would be at the bottom... is this correct or do you think I have 2 RHS calipers.
    Brendon
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    Default Re: Hilux calipers
    The bleed nipple should be at the top, facing inwards for both calipers when mounted.
    stidnam
    south australia
    Yeah, that's what I thought, be a bit silly having the bleed nipple at the bottom, pretty sure I've got 2 RHS ones, take them back tomorrow and get a left ones, then rebuild them..
    Should I use a primer paint first and then a high temp paint to finish??
    Brendon
    High temp metal paints do not require a primer coat. Most primers would deteriorate under the high temp associated with brakes.
    cheers Chuck.
    MS51Crown Coupe,
    south australia
    thanks guys, calipers getting swapped today.
  1. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 07:27 PM
  2. What rims clear hilux calipers?
    By sir_drift_alot in forum Tech and Conversions
    Last Post: 27-07-2007, 03:47 PM
  3. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 06:09 AM
