Page 2 of 11 FirstFirst 1234 ... LastLast
Results 16 to 30 of 157
Thread: 2JZ-GTE into MZ12
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    Default Re: 2JZ-GTE into MZ12
    As above... I did the same thing with my conversion, I needed to fabricate a new section where the twin pipe's merge into one, I make a nice flowing transition up and was getting Large spikes of boost with stock controls in place.
    Attachment 5384
    The 'cone' which is exactly that a cone from 3inch pipe down to a 2.25inch diameter section mimicks the restriction the factory cast 'Y' peice serves in the sytem allowing the boost to be controlled.I fitted my coen in the dump section where the 3inch outlet of the 'Y' peice connects to.
    Even with this restrictor in the system I was getting spikes over 14psi meaning I was still hitting boost cut.
    Direct consequence of more boost is fuel cut and possible destroying turbo's.
    User Conversion King
    NWA
    cheers for the info,
    i have no login but my BMW friend should have one
    hello
    NWA
    fuel filter is mounted, i just need to find a banjo->banjo flexible section.
    this is the wrong donut for the gearbox so the actual one will be slightly bigger. for memory this one is off a UZ or something. the real donut and a piece of tailshaft is on its way. i feel the clearance is sufficient to use the donut arrangement.
    this is the Z12 xmember with the JZS reubber mount. the holes have been elongated with a file and a new 5-8mm plate with 4 holes will be welded onto the bottom. the top also had to be recessed to clear the rubber mount. ill be restrengthening that section with some 5mm plate also .
    the gear shift rod has been shortened and bent for adaquate clearance. you may also notice the bolt in the gearshift is now pointing outward, ive reversed it. there was clearance issues with the RHS speend sensor/plug and also the 3 prong flange thing. it is close to the trans tunnel but even if it does rub there is no problems.
    thats it for now!
    hello
    vic
    If the aristo donut is too big the 1UZ one will be fine , thats how ive got around the problem before.
    Dave
    NWA
    the pcd is different though....
    so the 3 prong flange would need to be changed accordingly.
    after more looking at it all, it seems the JZS donut may work
    hello
    Flexiable fuel hose, banjo-banjo can be had from an EFI charade (that's where I''ve got them from in the past!)
    NWA
    when i was getting a sxv21 (model?) cable today, i pulled off a banjo-banjo hose (from same car).
    only problem is that the hole is slightly bigger on one side of the banjo. might have another look tomorow
    hello
    Don't forget you'll need a bit of clearance for the whole shebang to wiggle around on its rubber mounts.
    NWA
    yeh,
    there is a little bit of a clearance issue between the gearbox wiring loom bracket and the fuel lines.
    hopefully it doesnt move too much though.
    im getting some genuine engine mounts through toyota. they have some promo rubbish on called trade grade pricing. MS123 engine mounts (same as mz12) are $52.00 each
    i might still give it some tunnel bashing in places
    hello
    NWA
    whats the deal with the PS pump and lines?
    for memory this is a different pressure outlet to the 1JZ pump? therefore the RT142/RA65 straight-swap wont work?
    i might have to braze the RT142 pressure line to the existing short section already on the pump.
    pics
    hello
    In regards to the PS,
    The PS idle up (to stop the car stalling when you do a U turn ), and RT142 lines.
    If you ditch the aristo version and get a JZZ30 version (tis like a T piece with the PS idle up on the side), as opposed to the aristo version then the RT142 lines simply screw in...
    NWA
    cheaper to use 1min of gas brazing then to source a pump
    hello
    It's not the pump. It screws into the pump, and then the PS lines screw into it, an inline T for the PS idle up if you would...
    NWA
    so,
    fuel pumps. stock one might be a bit out of its league. internal pump arent they?
    some sort of falcodore is a easy fit perhaps?
    hello
    so,
    walbro.
    Have a look to check if it is internal / ext, that other GT LTD I had was external pump! (mine is internal)
    Stop stuffing around already
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  5. 1jz vs 2jz heads
