Results 16 to 20 of 20
Thread: 1JZ/2JZ Power Steering Seal/Rebuild Kit P/N
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default Re: 1JZ/2JZ Power Steering Seal/Rebuild Kit P/N
    ive got two 1jz p/s pumps needing rebuilding, from what i can see these part #'s are needed, anything else?
    The Bearing is 90363-17013
    Seal Kit is 04446-30120
    would it be easier to take the pump's + rebuild kit to a shop to fix or simple enough to figure it out myself?
    87' z20 Soarer - 1jz Gt35r -
    Western Aus
    Quote Originally Posted by BMWTurbo
    I thought I'd included this...
    Attachment 8388
    Attachment 8387
    You may get away with bearing and O-rings only if it's noisey, but Item 14, the seal is most likely where you'll have a leak it it's out of the front of the pump and the only place I could find for this was the rebuild kit.
    Also if pulling it down make sure you take note of the orientation of the vanes, they have a rolled and straight edge.
    i found they were the same on both ends?!?!
    it looks like toddo found the same?
    mine looked completely symmetrical, the only thing i can think of as to why yours weren't is that perhaps yours were heavily worn, maybe run without oil for a period of time causing premature wear?
    JZA70|R / 12.45 @ 111 mph.
    Western Aus
    mine was fucked cause i ran it without fluid.
    although im guessing it'd take a fuckload more than what i did to really effect the vanes, maybe BMWTurbo's were well well shagged.
    sus-023 Backyard Mechanic Slidin23's Avatar
    Apr 2007
    123 fake street s.a.
    i have a power steer pump on my 1jz that is making noise and also when i turn the wheel it doesnt turn the wheels for about an inch then starts turning. does this going both ways and the steering wheel is never cenetered when you turn it back. always an inch out either way.
    the pump is also noisy.
    will i need to replace the veins inside the pump if i rebuild it? toyota just uoted me $107 for a gasket kit. the pump isnt leaking or anything so i doubt its anything to do with that.
    i have replaced the lines and the rack. so they are all fine. suspect it is the pump.
    btw i have a 1jz in an mx83. pretty sure its jzz30 pump. although i dont have the usual pop in power steer line with the o ring on it. mine has a thread in it with a fitting.
  1. Power Steering pump what do I have?
    Last Post: 29-04-2007, 11:35 PM
  2. 4A Power Steering Pump Upgrade
    By Bazooka in forum Tech and Conversions
    Last Post: 23-01-2007, 11:16 AM
  3. SW20 Power Steering Rack
    Last Post: 16-01-2007, 04:37 PM
  4. power steering fluid
    By off-road in forum Tech and Conversions
    Last Post: 12-03-2006, 09:48 PM
  5. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 29-12-2005, 12:52 AM
