Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: braided brake lines
    Default braided brake lines
    Hey guys,
    Just a quick question, i was wondering if you are legally allowed to run braided lines under the car for brakes or do they have to be steel. I've already had 3/8 fuel lines made out of bundy but if i was legally allowed to have braided it would make mounting the line alot easier for me.
    I know alot will say wat a waste of money but for my personal ease of installing money isnt really the issue
    Default Re: braided brake lines
    should be able to find the info you need here... http://www.braidedhoses.com.au/
    cheers mate
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    I got braided hoses made for the front of my 40 that were a lot cheaper then buying the 4 hoses new. $120 dollars I think.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    you could run every line for everyting in braided, but it would be REALLY expensive, as you cant just use earls fittings and braided line you have to get the crimp on ADR ones made for you
    also you should regularly inspect braided lines,
    IMO run steel bundy tube it cant be THAT much harder and is safer and easyer to comply with road laws
    and while braided lines might have less expansion than a non-braided hose (but in reality, most are just the same due to their construction), they will definitely have more expansion than a steel tube....
    having long lengths of flexible hose is a great way to kill pedal feel
    but if it makes you happy....
    edit: those Braidedhoses.com.au lines are just teflon lines with a pretty braid on top...
    the strength comes fromt he teflon. the braiding is JUST THERE TO LOOK PRETTY!
    (and stop abrasion.. which is the real reason to have a metal braid on top of a rubber line anyway....)
    Take the extra money that the braided lines would cost over proper bundy tube and use it to pay someone else to mount the proper tubes.
    Jun 2007
    Is there anyway to tell ? Either by their cost from the Dealer or just general make of the vehicle ? (Ahem, 03 low-spec Corolla)
    The difference in expansion is like you've noted, very little, but I wonder if anyone has tested the difference around a track where the lines may become heat-soaked ?
    if you just fit braied lines to one axle, you wont notice it as much, but fit them all round and you will have a firmer brake pedal,
    it is noticeable.
    but also comes down to cond of old brake lines, we recently fitted braided lines to a VZ commy with 170ks on it, and the owner was stoaked with the new pedal feel,
    (off the shelf lines that he supplied to us, no idea what brand they were)
    Mar 2008
    westmere
    in New Zealand you are able to , hoever they must not cross under any chassis rail under the passanger compartment and they must be certified.
    Backyard Corolla Kid Grease Monkey
    another thought that has crossed my mind...is there much point to running a braided clutch line?
    the setup is:
    RWD 4age, 4 Puck heavy duty clutch, light weight flywheel, T50
    I ran a braided clutch line as it was easier and cheaper than having bundy tube made and fitted to suit...
    Jase
    JZA023
    You may feel a difference with braided clutch lines, but would it make a difference to how you change gears?
    I very much doubt it.
    it is noticeable.
    so.. you changed an internal rubbe rline with an internal teflon line and the owner was stoked with the pedal feel
    as i said months ago, the braid is there to be pretty and resist wear, not to give any strength.
    if you want a firmer pedal, got lines with stronger internals... is about as simple as that
    Chiba
    How can I tell which brands/types are stronger? I'll be looking at this sort of thing soon for AE101 Levin (superstrrut), I'm happy to pay for good stuff.
    By The Witzl in forum FAQ
  2. DIY fuel and brake lines
    By Norbie in forum Tech and Conversions
    Last Post: 08-04-2007, 08:53 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
