Results 16 to 30 of 31
Thread: Elec Power Steering Pump
    Default Re: Elec Power Steering Pump
    how weighty in comparison to a standard powersteering pump?
    might be the easy way for me to go...
    Quote Originally Posted by BeRad
    Bill, is it a standalone unit, with hoses running to the steering box or is it built into the steering box?
    It's got hoses that run to/from the steering rack.
    And connectors for power.
    Quote Originally Posted by love ke70
    Not sure, I guess about twice as heavy - It's a bit bigger (longer) than an alternator.
    www.billzilla.org
    Toymods founding member #3
    Forum Sponsor Conversion King
    there about 5kgs from memory.
    the only thing im still not sure about them is the psi there rated at, cant find any info and havn't tested one yet.
    not sure if it will still turn the tyres with high loads also ie: front end of an mr2 would be light by comparison to a 1uztt 4wd ta22. would be nice to know first.
    linden
    linden
    Run 48V !
    www.billzilla.org
    hmmm i think that would require some work but then again check out the rest of jamies stuff and you just know that he's got way too much spare time on his hands.
    linden
    New Zealand
    MR2 version is commonly used in stockcars here in NZ, presuming you can find one. My brother has been looking for ages.
    Callum
    Junior Member Grease Monkey Jaffa's Avatar
    linden
    I wish that was true
    Hey! Thanks for all the replies guys, it has given me plenty of options to go look at ,..
    Yep it is a room thing ,.. i might be able to get in a small mech drive pump but jeez it want to be small ,.. i think an elec pump is looking the goods
    You can get really small hyd pumps from EATON. Probably around 3inch od and up to 6 inches long, but it's been long enough to blur any memory of capacities in relation to flow rates and pressures (though being used in hydraulic apps I'm sure it would have been enough)
    Friends
    Montrose
    Many cars just use an electric motor mounted on the steering column and avoid any hydraulics. They fit these to V8 supercars, so they'd probably be available as an aftermarket part, but I can't say anything about pricetag though...
    interesting concept mrshin, i might dig into that.
    quaiffe quick rack, powersteering ends and more teeth cut into the rack.
    add the powersteering and it may be manoeuvreable in carparks....
    Quote Originally Posted by off-road
    New mini too I think
    no, that's electronic power steering, not an electric power steering pump
    Quote Originally Posted by mrshin
    yeah, current model rav, yaris, corolla, tarago,... also a smart unit which is speed sensitive too, varies assist with speed
    Montrose
    Pfft.
    http://www.musashi.com.au/cpa/htm/ht...&product_id=81
    you've never driven a ke70 with a 1ggte in the front on sticky 205's
    come back when you can handle no pwr str 1G in a 28
    Black Betty >HERE!<
    (\__/)
  1. how to use 1jz hydro. water pump for power steering
    By 1jzracing in forum Tech and Conversions
    Last Post: 25-09-2009, 09:42 PM
  2. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 02:51 PM
  3. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 29-12-2005, 12:52 AM
