Results 16 to 27 of 27
Thread: Toyota Odd Upgrades (TOU#) with other Marque Parts
    Default Re: Toyota Odd Upgrades (TOU#) with other Marque Parts
    Hm, i always thought US tail lights were different.
    Anyway, according to the Starion brake upgrade on AuStarion the Nissan Patrol 17/16" master should also fit the AE86, or for that matter any 2bolt 80mm spacing booster. The following quote from the AuStarion brake upgrade PDF gives more details:
    The master cylinder chosen is a 17/16 inch bore unit specified on some Nissan Patrol’s. The unit itself is an aftermarket type, PBR part number J1715, which comes in a Lucas box, and contains a Tokico master cylinder! It has the same 80mm mounting centre holes as the Starion unit, and will bolt straight onto the Starion brake booster.he booster has a pushrod length adjustment,
    Since the Starion one fits the AE86 i would think that the only issue might be strut tower clearance. Ill be giving it a go though, esp as Mitsu no longer make Starion bits.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    yeah but you can still get brand new starion master cylinders for under $200. mitsubishi never made the master cylinders, it another brand, cant remember what.
    Ah, because everywhere i have phoned up in the last week have given a big nay to them actually still being produced.
    Anyway, this is a good option for those using R32 calipers which stock have a 17/16th master.
    hmm i might have to look into that myself, cause im upgrading from hilux to S14 calipers, these may need a bigger m/c than 15/16th.
    Ok, slight correction. Seems the AuStarion brake upgrade page was wrong. Its actually a JB1775 not a 1715. Be careful with that one, the 1715 is a 13/16th master.
    The JB1715 looks like this though:
    Junior Member Backyard Mechanic M.J.H's Avatar
    Ford falcon XF 60 Amp alternators can have the rotor and stator used in KE70 Bosch alternators... bumping it up from 30-40A to 60A, perfect or EFI upgrades to K series motors.. you use the KE70 front and rear housing, but the regulator is identical. it makes the whole thing about 5mm longer, so you need to find longer bolts to hold the alt together, and make a small spacer at the rear mount to the bracket on the block.
    Also works on the 18R bosch alternators.great for getting rid of the external reg for a high output internal reg altenator.
    Would probably work for most bosch alt's as well.
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    Is it true s13 suspension will fit in Xa6X celicas ?
    i've heard from a few ppl it will fit but i have yet to stand infront of a celica with s13 suspension
    Yes, but you need to cut and shut the lower control arms. Same as the AE86 conversion.
    tas
    care to elabtorate ?
    Thats not for this thread, look up how the S13 conversion is done for the AE86 and copy. Or start a new thread for that specific conversion.
    I don't want to be a Domestic Engineer bnicho's Avatar
    The rear plate on the block that holds the main seal on an 18R (just above the sump) is identical to that fitted to Isuzu G161/G180/G200 SOHC engines.
    Junior Member Domestic Engineer psychofox's Avatar
    More AE86 Master Cylinder Swaps....I can confirm (as I have it installed currently) that a Nissan Navara (D22) Master is 2 bolt and is 15/16th PBR Part No. JB9735 or JB9736.
    Here's A Pic of it on the AE86 Master before I did all the brake lines
    By The Witzl in forum FAQ
  2. Toyota R Engine History
  3. Brake upgrades for FWD/AWD 5x100
    By wagonist in forum FAQ
    Last Post: 06-09-2005, 11:38 PM
