Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: Nut from hell - AE92 driveshaft nut
    Hoppers Crossing
    Default Nut from hell - AE92 driveshaft nut
    Hey folks
    Any ideas on how to remove the 30mm nut from the driveshaft (essentiall holds the upright to the hub/driveshaft) on my AE92?
    I've hit it with RP7/WD40/Stitch0/rattle gun but no comey offy.
    I havent tried heat (as yet)
    I could crack it with a 6ft breaker bar - but it still "rotates" and hence won't come off?
    Unless I do it with someone in car with foot on brake and car on ground?
    Any ideas?
    Default Re: Nut from hell - AE92 driveshaft nut
    Hand brake on, chock all the wheels and attack it with that 6 foot bar you have.
    1" rattlegun w 190psi.
    Junior Member Domestic Engineer psychofox's Avatar
    yeah I had one of these basically felt like it was welded on - ended up borrowing a 3/4 rattlegun and it came off. The best bet to start with is always to try and loosen them on the ground with someone standing on the brakes.
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    Hoppers Crossing
    plonka. yup. i reckon that will work
    chris. i dun wanna put the thing into a geostationary orbit mate
    psychofox ; last i tried car was on stands ; so ; gheyness applied.
    now that its on the ground will get SWMBO to stand on brakes with handbrake on and see how we go.
    thanks guys
    Yeah, i must say the halfcut i did it with a rope tied to the towbar of another car around the dash bracket, and then attacked it with a 5m extended breaker bar. Took 2 Snap-On breakers to loose it (first one snapped just past the head)
    yeah out the wheel back on,drop it on the ground, then have a crack,
    had the same prob with a honda FULLY sick accord!
    Hoppers Crossing
    thats the plan, will see how we go.
    the balljoint ain't that flogged ; but ; i've replaced one may as well replace the other
    yeah, take centre caps out of wheels, put car on ground, in gear, handbrake on, person in car holding the brakes on
    get your longest breaker bar with pipe on the end and go for it
    otherwise just get 3/4" rattle gun and make sure there is plenty of pressure behind it
    i have the same problem with the ones in the rear of BMWs,
    They have a locking ring that you cant actually get out, so you get a 1" and slowly increase the pressure until it straightens out the lock ring..
    just make sure your going in the right direction can have some pretty funny results otherwise
    senior backyard mechanic Grease Monkey legend's Avatar
    hit it with a flat cold chisel in 3 places then tighten slightly then "hopefully" it will undo
    get someone to apply the brakes and put something between two of the wheel studs so when rotated anti clockwise it fouls on the ground and stops the hub from turning (a large prybar or extension does well), the combination of that then get a nice long bit of pipe over the end of a breaker bar and you'll get it
    normally just something between the studs is good enough, but on tough ones I like to use a combination of the two to lessen the risk of breaking a stud
    I am the sun
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    Quote Originally Posted by Dale
    yes dale and i have used this quiet a few times on our cars and it works really well
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
    Done it twice on my car and there a piece of piss (3 times if you count the passeneger side).
    First time I had two people so we jacked the car up and stood on the brakes while the nut was undone.
    The second time I took the wheel centre off and cracked with the car on the ground and the handbrake on. From memory I used a big long bar clamp over a ratchet as a breaker bar They really weren't that hard to do each time, and each time they were torqued correctly.
    As far as putting something between the studs and ,letting it hit the ground I reckon there a good chance of bending studs if the nut is really tight. Depends on the lever length obviously, but I wouldn't reccommend it, specially when there are better ways of stopping the shaft rotating
    Hoppers Crossing
    thanks all for the feedback here ; i'll give it a shot this weekend (if i'm not working)
    By The Witzl in forum FAQ
  2. GUIDE - Cheap AE92 Quick Shift
    Last Post: 01-04-2014, 09:53 PM
  3. AE92 Master Cylinder Upgrade?
    By DiZ in forum Tech and Conversions
    Last Post: 26-04-2013, 02:40 PM
  4. GUIDE - Cheap AE92 Quick Shift
    Last Post: 22-02-2007, 09:23 AM
