Results 46 to 59 of 59
Thread: F series diffs
  1. #46
    Default Re: F series diffs
    Not sure what my first gear speed at redline is, I'll check next time im out in it
  2. #47
    Whatever you've got now, you need to get a reasonably tall ratio to make the best of that 7M torque. Turbo engines love to be loaded up, it gets them on boost quicker. The 1st gear acceleration improved dramatically in my car when I swapped from 4.1 to 3.58:1.
  3. #48
    So I'm looking for a manual RA65 diff then?
  4. #49
    If you want a 3.5 like Norbie, yes.
  5. #50
    I think some manual RT142's had a 3.5 F series as well.
  6. #51
    I'd personally go with 3.73 instead though.
    I'd just assume the 2JZ would come on boost earlier than the 7M, especially if you upgrade the 7M turbo.
  7. #52
    All the more reason to go higher gearing. Load = earlier boost = good.
  8. #53
    Act
    I was hoping you would say that Norbie
    With the W50 I thought that i could of even gone lower than 3.5 in the wagon maybe 3.2 or so with the GE it seemed to rev a bit hard on the hwy and 1st was usable but coud of been better. However now I'm glad to here the W58, 3.5 and GTE are going to be a great combination.
    Last edited by TheStitt; 17-02-2006 at 08:51 AM. Reason: damm early morning spelling
  9. #54
    I would like to be a Backyard Mechanic 3t-RA40's Avatar
    You know I love ya.
    I know this is off the diff thing but I have a question for you CrUZida. The new bushes in the sub frame, did you have them made or are they an off the shelve item.
    Neil.
  10. #55
    Rear Cross-member To Chassis Mount SPF1447K $115[Listed under Supra but assume is same as IRS Celica 4B,2T[/b]
    http://www.toymods.net/forums/showth...ht=MA61+noltec
  11. #56
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Handy hint: Don't try swapping ring gears over yourself unless you have a strong bench vice and/or a rattle gun. The bolts are torqued up REAL tight!
    Found this out yesterday, thought i'd be able to muscle them (or use a hammer + ring spanner) but they are way too tight for that. Oh well, another day
  12. #57
    Thanks mate i'm ringing up about them right now.
  13. #58
  14. #59
    Thanks mate that's great i'm chasing them up as we speak.
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 09:43 PM
  3. t series diffs
    By spoon in forum Tech and Conversions
    Last Post: 03-01-2006, 01:11 AM
  4. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 06:14 PM
