Results 31 to 45 of 61
Thread: Brake Upgrade - KE20 with Twin Piston Caliper - Research Stage
    ......................... Carport Converter
    Default Re: Brake Upgrade - KE20 with Twin Piston Caliper - Research Stage
    With a ta22, do they have a floating disc? Or is it the hub incorporated into the disc?
    Mic
    Is the 206 4 x 114.3?
    ([][][]II--LT--II[][][])
    TA22 is bolted to the back of the hub
    My KE25 thread
    Quote Originally Posted by Megz
    Mic
    Floating... TA22 is a solid disc though, it is a bit bigger than the KE20, but I don't think enough to warrant the work involved...
    28, you just looking at changing brake setup or have you considered struts as well?
    Mic
    No, and neither is the back bolt pattern on your hub It's not the same as the front and you'n not want to fit such a flat disc over a KE corolla hub, your caliper is going to be so far out past the hub face you'll never find wheels to fit
    My KE25 thread
    Fair enough. Maybe changing struts will be easier for a brake conversion? I guess this all depends on how much you want to spend,
    Mic
  8. #38
    Well definately consider changing struts, but at the moment, will just try to use to KE20 struts... (Same as KE25?)
  9. #39
    It's not floating, the disc is bolted to the back of the hub like most RWD toyotas.
    Floating (even though it's not truly a floating disc) refers to disc over hub
    My KE25 thread
  10. #40
    Yeah, I just realised that the hat height is smaller, therefore pushing tha caliper outwards more, and as you said will never find wheels that fit...
  11. #41
    Ahh, I was thinking floating was just not one piece... Me understand now...
  12. #42
    Yep.......................
    My KE25 thread
  13. #43
    Thanks for all you assistance guys... This hopefully will help many in the long run...
  14. #44
    EDIT: You beat me to it shane!
    Mic
  15. #45
    Yeah i once i get my 20 home and sorted, Will look at an upgrade so this is helping me too!
    Mic
  1. Replies: 148
    Last Post: 22-04-2008, 09:01 PM
