Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
Thread: Brake Upgrade - KE20 with Twin Piston Caliper - Research Stage
    Default Brake Upgrade - KE20 with Twin Piston Caliper - Research Stage
    Background
    My girlfriend has a ’73 KE20 and would like to put in either a 5K or possibly a 20V in a year or two, and will most likely need better brakes for the Engineer’s Cert…
    But she would like the 12” (possibly 13") steel wheels and hub caps to remain…
    Purpose
    I would like to find a disc, preferably vented, that fits similarly to the original KE20 disc, and a suitable twin piston calliper to match, whilst still allowing the 12” (possibly 13") wheels to fit over the top…
    Current Research Findings
    Original KE20 disc specifications:
    200mm x 10mm with a total height of 36mm, a 64mm centre hole, and a 4 x 110 PCD (Solid)
    RX-7 Series 1/2 disc specifications:
    228mm x 18mm with a total height of 59mm, a one-piece hub, and a 4 x 110 PCD (Vented)
    AE90/92/93 (DOHC) disc specifications:
    238mm x 18mm with a total height of 48mm, a 54mm centre hole, and a 4 x 100 PCD (Vented)
    AE101 disc specifications:
    238mm x 22mm with a total height of 48mm, a 55mm centre hole, and a 4 x 100 PCD (Vented)
    NCP10/12 disc specifications:
    235mm x 18mm with a total height of 43mm, a 55mm centre hole, and a 4 x 100 PCD (Vented)
    Conclusion
    So far I believe the RX-7 Series 1/2 disc with an alloy twin piston caliper like the R32 GTR/GTS-T Rear Caliper (suits 18mm disc) would possibly make a suitable combo, and would provide excellent braking characteristics…
    Another option is the NCP10/12 (Echo) disc with an alloy twin piston caliper like the R32 GTR/GTS-T Rear Caliper
    Both discs could be machined down ~5mm, and this would give more chance of the 12” wheels fitting, and 13" wheels should (may) fit without the machining…
    Will further the research over the weekend…
    ([][][]II--LT--II[][][])
    Default Re: Brake Upgrade - KE20 with Twin Piston Caliper - Research Stage
    well.. the 218mm discs witht he sliding calipers don't fit under 12".
    better brakes means bigger disc. even if vented, the brakes will still be as hard to push, and not slow the car any faster.. but you will have more fase resistance.
    early Galants had opposed twin pots, but still the disc size is the issue.
    why can't she go to 13" (and then KE30 brakes) and still have hubcaps?
    ......................... Carport Converter
    Could you look at something from a Charade? That would have similiar characteristics to the Echo/Yaris. Just an idea,
    Mic
    Isn't the KE20 4x110?
    Quote Originally Posted by Joshstix
    I have a feeling you're right, which has just ruined half an hour's research... Meh, I was bored at work anyway...
    Yeah early rolla's ke1X-ke2X are 4x110
    Mic
    but KE30 hubs go onto KE10 and KE20 stub axles with a change of bearings .. so 4x114.3 is still in the game
    rear is just modified axles etc away
    Back to the drawing board... I shall continue to find a suitable upgrade, and will look into going the 13" wheels with hub caps... (These would be 4 x 114.3???)
    I was after I read the specs from http://www.thansen.dk/wm_car.asp?c=1...2&wn=360272154 and remembered the late rollas are 4 x 100 also, but the KE20 specs must be wrong on that site...
    Yeah it would be 4 X 114.3. My old 25 use to run mazda rx7 stockies 13" as they have the 4x110 pattern.
    Mic
    Quote Originally Posted by Megz
    That's very handy info... (Damn, now I have that "This is Handy" ad in my head... )
    Wonder what the brakes are like from early mazda's? Maybe look at that as well for ideas.
    Mic
    Look's pretty good...
    ......and a different inner dust seal as the KE20 is tool small OD for the later model hub. I did the swap a month or two ago.
    My KE25 thread
    Quote Originally Posted by twentyEight
    228mm x 18mm with a total height of 59mm and a ??mm centre hole and a 4 x 110 PCD (Vented)
    Should add that info to the first post as it keeps all the comparisons together,
    Mic
    Few steps ahead of you... Actually, we seem to be thinking the same at the same time...
    Conclusion has also been edited...
  1. Replies: 148
    Last Post: 22-04-2008, 10:01 PM
