Background
My girlfriend has a ’73 KE20 and would like to put in either a 5K or possibly a 20V in a year or two, and will most likely need better brakes for the Engineer’s Cert…
But she would like the 12” (possibly 13") steel wheels and hub caps to remain…
Purpose
I would like to find a disc, preferably vented, that fits similarly to the original KE20 disc, and a suitable twin piston calliper to match, whilst still allowing the 12” (possibly 13") wheels to fit over the top…
Current Research Findings
Original KE20 disc specifications:
200mm x 10mm with a total height of 36mm, a 64mm centre hole, and a 4 x 110 PCD (Solid)
RX-7 Series 1/2 disc specifications:
228mm x 18mm with a total height of 59mm, a one-piece hub, and a 4 x 110 PCD (Vented)
AE90/92/93 (DOHC) disc specifications:
238mm x 18mm with a total height of 48mm, a 54mm centre hole, and a 4 x 100 PCD (Vented)
AE101 disc specifications:
238mm x 22mm with a total height of 48mm, a 55mm centre hole, and a 4 x 100 PCD (Vented)
NCP10/12 disc specifications:
235mm x 18mm with a total height of 43mm, a 55mm centre hole, and a 4 x 100 PCD (Vented)
Conclusion
So far I believe the RX-7 Series 1/2 disc with an alloy twin piston caliper like the R32 GTR/GTS-T Rear Caliper (suits 18mm disc) would possibly make a suitable combo, and would provide excellent braking characteristics…
Another option is the NCP10/12 (Echo) disc with an alloy twin piston caliper like the R32 GTR/GTS-T Rear Caliper…
Both discs could be machined down ~5mm, and this would give more chance of the 12” wheels fitting, and 13" wheels should (may) fit without the machining…
Will further the research over the weekend…
