Results 1 to 3 of 3
Thread: st162/165 famous starter problem - quick question...
    victoria
    Default st162/165 famous starter problem - quick question...
    hey guys,
    for those familiar with the 4th gen celica starter motor problem, i am putting in a relay switch that will help pass power to the starter motor to get it to start. my problem is, i cant find a lead that has +12v when the key is turned over to ignition? (and only when the key is turned on to ignition)
    ive tried to follow the below diagram i've found on other forums, but am unsure of what "ignition side of starter motor" is???
    is it the fat but short blue cable (on the opposite side of the other 2 cables) of the starter motor?
    THIS IS THE GUIDE IM FOLLOWING
    and my question is, is the fat blue cable what i should be connecting to the 'ignition side of starter wire" on the relay switch?
    1st car - 1988 Corolla ae82 4ac
    2nd car - 1988 Corolla 4age 100kw
    3rd car - 1989 Celica st165 GT4
    (and toyospares has been the second home for all of them! hehe)
    1st bike - 2002 Kawasaki GPX250
    Default Re: st162/165 famous starter problem - quick question...
    Check here, http://toymods.net/forums/showthread...referrerid=119
    Ignition power is in the starter wire. the thinish wire with the black plug. undo the plug and connect to each side of it. run 12v Battery to the other pin and earth to the other.
    victoria
    yep cool, thanks for that.
    i figured it out after i wrote the post, think it was just one of those times were u've been in the garage for too long and need a quick break to reset!
    thanks for the reply tho!
    seems to be all sweeet now.
  1. Quick question re: shock absorbers
    By greywolfe in forum Tech and Conversions
    Last Post: 06-03-2007, 02:19 PM
  2. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
