Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Where to go for Head Porting ?
    Penrith BC
    Default Re: Where to go for Head Porting ?
    or in the voice or borat...
    the secrecy and intrigue are NOT ! killing me
    or perhaps
    the secrecy and intrigue are killing me (1...2...3...) NOT !
    or even
    the secrecy and intrigue are killing me (taps hand on lap...) NOT !
    youll never get some of this!....
    ../delete/ban
    tech moderator
    IB 4G63 SOHC, or 4G93 SOHC
    I thought there were mrsbitchy motors that were in that family and were 16V but SOHC?
    Facebook | LinkedIn
    Jun 2007
    Quote Originally Posted by stradlater
    There are !
    It doesn't really matter what exact Head it is anyway.........
    Does anyone know the acceptable minimum Head Flow velocity ? I.e. for when practically hogging out the Ports.....
    All depends on what RPM you want to optimally run at, the cams you are running, the size of valves, compression ratio, capacity..... you cant just pick a number out of the air.
    Jun 2007
    Ok then.....
    Inlet Port Diameter: 38mm (Doesn't mean choke diameter......// Haven't dissembled it to check)
    Inlet Valve Diameter: 44mm (Can go 1-2mm Oversize...)
    Exhaust Port Diameter 38mm
    Exhaust Valve Diameter: 38mm (Will go 2mm Oversize, from previous experience here...)
    Static CR will be 9.5 or 10.5:1 with displacement 2.2L or 2.4L respectfully.
    4000-7000 RPM
    Cam duration and lift really depends on Flow no's data more then Flow no's depending on cams.....
    Penrith BC
    ../delete/ban
    tech moderator
  8. #38
    The new trend of porting heads seams to be actually filling on the port
    I recomend. "Liberty Speed" based in Tamworth.... 0267623636
  9. #39
    Jun 2007
    Quote Originally Posted by ed_jza80
    Thanks, always good to read up on unread Mach Index discussions.
  1. 18rc cam and porting question
    By hosking1991 in forum Tech and Conversions
    Last Post: 11-12-2006, 07:58 PM
  2. 22RE head porting?
    By Hibino in forum Tech and Conversions
    Last Post: 21-11-2006, 10:48 AM
  3. manifold porting, which tool?
    Last Post: 15-03-2006, 08:23 PM
