IB 4G63 SOHC, or 4G93 SOHC
or in the voice or borat...
the secrecy and intrigue are NOT ! killing me
or perhaps
the secrecy and intrigue are killing me (1...2...3...) NOT !
or even
the secrecy and intrigue are killing me (taps hand on lap...) NOT !
youll never get some of this!....
../delete/ban
tech moderator
I thought there were mrsbitchy motors that were in that family and were 16V but SOHC?
There are !Originally Posted by stradlater
It doesn't really matter what exact Head it is anyway.........
Does anyone know the acceptable minimum Head Flow velocity ? I.e. for when practically hogging out the Ports.....
All depends on what RPM you want to optimally run at, the cams you are running, the size of valves, compression ratio, capacity..... you cant just pick a number out of the air.
Ok then.....
Inlet Port Diameter: 38mm (Doesn't mean choke diameter......// Haven't dissembled it to check)
Inlet Valve Diameter: 44mm (Can go 1-2mm Oversize...)
Exhaust Port Diameter 38mm
Exhaust Valve Diameter: 38mm (Will go 2mm Oversize, from previous experience here...)
Static CR will be 9.5 or 10.5:1 with displacement 2.2L or 2.4L respectfully.
4000-7000 RPM
Cam duration and lift really depends on Flow no's data more then Flow no's depending on cams.....
go here and read:
http://www.v-eight.com/tech_forum/viewforum.php?f=4
inparticular, read this thread:
http://www.v-eight.com/tech_forum/viewtopic.php?t=268
../delete/ban
tech moderator
The new trend of porting heads seams to be actually filling on the port
I recomend. "Liberty Speed" based in Tamworth.... 0267623636
Thanks, always good to read up on unread Mach Index discussions.Originally Posted by ed_jza80
