Page 1 of 5 123 ... LastLast
Results 1 to 15 of 63
Thread: Electrical gurus: How can my charging system be doing this?
    Question Electrical gurus: How can my charging system be doing this?
    OK, so i've been battling with an electrical charging system issue in in my AE71 since the 1JZGTE conversion. Basically when under load, the system voltage drops to 11.5 volts as it comes onto boost around 3500rpm, then settles at a still low 12.7 volts to redline. Any other time when cruising, idle, etc the alternator happily cranks out a steady 14.00 volts.
    I can't replicate the problem by free-revving the engine whilst stationery, it only happens under load.
    I'm running the factory 1JZ alternator, with wiring customised to suit (was originally external reg with the 4AC engine), this wiring has not changed since my previous 4AGTE conversion which worked perfectly.
    I have tried two alternators with exactly the same result, so that can be eliminated.
    Any ideas? Throw anything my way, i've tried many things already but will happily listen to any suggestion no matter how trivial it may seem, as i'm going insane chasing my tail at the moment!
    Phil
    Default Re: Electrical gurus: How can my charging system be doing this?
    A bad earth on something that is only active under high load...
    I am the sun
    senior backyard mechanic Grease Monkey legend's Avatar
    belt slip?
    running a dedicated wire from the alt to the battery? running a dedicated earth lead from alt housing to battery?
    check earths from block.
    check that bolts from alt to bracket to block are tight and there is electrical contact...
    etc
    Montrose
    Adding another earth lead never hurt nobody... Several times I've seen earthing that looks like it should be fine just not doing the job at all times, but add another one and all is fine.
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    check tightness of all wiring connections,especially earths, it could be that as the engine moves on its mounts under load, a connection may separate or partially separate and give you a lower charge rate.
    and cleanliness of the earth points..
    or one of the field diodes might be failing (could happen in 2.. ya never know)
    scope the output? or get an LED voltage monitor thingy from jaycar?
    Sounds silly but is the old external reg still in there somewhere?
    Edit: judging by what ive seen of your engine bay i doubt it is
    Black Betty >HERE!<
    (\__/)
    Jan 2007
    I agree you have a Earth problem .... Id say around the injector area check the harness earth to the intake runners ...
    Keith:
    whoa, thanks for the quick replies!
    Bad earths: unlikely, i've checked all connections and added two extra earthing points to clean bosses on the chassis
    Belt slip: Possibly, although i'd imagine the belt would have to be slipping savagely for the alternator to spin that slowly that is puts out practically no charge. There's no signs of slippage on the belt either.
    Battery is located behind the passenger seat, terminates at the starter motor, same place where dual 6mm cables connect from there to the alternator.
    The motor moves very little under load, the JZ is on stiff mounts. I have driven the car with a digital multimeter connected directly to the battery with a passenger monitoring the voltage, plus the voltage readout on the ECU handset confirms the same.
    External reg is somewhere in landfill, nowhere near my engine bay
    Keep 'em coming!
    Jan 2007
    Hmmm a relocated battery .... try a temp earth Alt to Batt see how you do ...
    Keith:
    Quote Originally Posted by KGB
    Keith:
    Huh? You mean like directly from the body of the alternator all the way back to the battery?
    yup 10 chars
    also look for anything which might move backward during accel (ie, boost), and see if anything can short..
    does it happen on the dyno?
    User Conversion King
    NWA
    it might be worth putting the multimeter on the IGN and Batt pins while doing a 'boost run' to moniter their voltages. if either drops lower then the actual battery voltage then youll have a problem. then again if the BATT pin decreases, the alternator output will increase.
    anyhow check the IGN pin for continuous 12v.
    might be also worth checking the tightness of the +ve pole nut on the alternator (sounds silly i know!)
    hello
    NWA
    and you may want to also consider that the voltage drop is caused by a large current draw (ie short). cranking usually drops the voltage to about 10v so it would have to be a short on one of the thicker unfused wires
    hello
  1. Mounting radiators - electrolysis(?) concerns
    Last Post: 28-09-2014, 02:58 PM
  2. 1UZ-FE starting problem for the electrical Guru's
    By "Z" UTE in forum Tech and Conversions
    Last Post: 14-06-2006, 10:46 AM
  3. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
