Results 1 to 9 of 9
Thread: 1JZ filling 2 cylinders with fuel
    Default 1JZ filling 2 cylinders with fuel
    from another forum, guy hasnt got membership here yet
    Hey guys I have a 1jz in a cressida witch is running really rich in cylinder 5 and sometimes 3, its not coils its not plugs and its not injector cause iv swapped everything around and its still filling the same cylinders up.
    I can have empty cylinders with no coils on so it doesn’t start and I can turn it over and after a few seconds the motor will lock up, take the plugs out and cylinder 5 is full and sometimes 3
    Iv looked at the ecu pin outs and just so happens that number 5 and 3 injector are on the same pin??
    Please help!
    The boobs are back
    Default Re: 1JZ filling 2 cylinders with fuel
    injector driver locked open?
    Change ecu's with someone to check?
    Junior Member Domestic Engineer NeoNasty's Avatar
    Yeah Id say ECU may have shit itself. Try another one and see what happens.
    HZJ75, RS41, JZZ30
    Roll Ons? Carport Converter Endless's Avatar
    Rip the cover off the ECU, i'd almost put money on the capacitors leaking.
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    Also check the the wire between the computer and 3/5 injectors has not worn through somewhere and is earthing out, as this will open the injectors whenever the ignition is on.
    MATT.
    Forum Sponsor Conversion King
    f#$%d ECU ive had this happen b4.
    see if you can find one second hand as when i got the said ecu repaired they charged $500 for it. it was 2 caps and a resistor. work that out
    linden
    ps it was the same cylinders too. so swap the plugs to other cylinders to check.
    Corona loving Grease Monkey TTMX83's Avatar
    Is this it??? http://forums.toyotacressida.net/for...ad.php?t=49950
    There is a fair bit of info and I had the same problem.
    Cheers Brad.
    thats him.
    The boobs are back
    linden
    Do you happen to know or can find out what resistor was changed? I have two broken ECU's here and have replaced the caps, possibly if I changed the resistor in it, I might get one of them working as a spare.
    Quote Originally Posted by Mr DOHC
    thats him.
    Have you got any fault codes from it yet?
    Cheers Brad.
  1. 4ac not getting fuel
    By Wedged'86 in forum Tech and Conversions
    Last Post: 18-04-2007, 08:57 PM
  2. fuel setup
    Last Post: 12-09-2006, 08:24 AM
  3. Car dying all of a sudden - Fuel pump?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 28-05-2006, 12:27 PM
  4. Replies: 1
