Cont...
These were also cut out in steel.
Then tack welded in place.
The mounts were then removed from the car for final welding.
I also trimmed the wings off the flat plate to allow easier access to the bolts on the block.
Final test fit.
This can be done even with minimal tools at home. All you would need is an angle grinder and drill (very cheap from bunnings, super cheap, etc) and a welder to tack them up, which you could hire from Kennards, etc. You don't need to be a good welder to tack them together, just as long as they hold so that they can be welded properly.
Hope this helps some one out.
