AFAIK lots of people like Adaptronics. Seems like a really good price too. I just recommend Microleb because I use one and like it a lot![]()
As Norbie says, wouldn't want to upgrade twice. 440's have been knock to make up to 295rwkw so they should be enough for the 480.
LT10s can run a 1jz but it is in waste spark setup. Rexnun runs one on his BIG single 1jz. Unsure if he is using the map I gave him at the moment?
I do think the 480 is a better option for a street driven 1jz. Should have enough to make around 300rwkw if you push it. And it makes sense for you having 440's and a walbro already. If you have an 044 and 650's then using the 560 would make more sense.
Stock ecu with safc should do you fine however if you do push the boost up then you may find that boost cut won't actually rise as you won't need to take any fuel out ie. stock ecu has 90% duty at 14psi with 380cc, If SAFC is left at zero then this will be the same. If you put+ve % in to add more fuel then boost cut actually drops. So you may need to wire in a FCD as well? That is a suck it and see type thing I reckon.
BTW don't want to follow my footsteps. Take for ever just to run a low 12![]()
