i think 13 means you've disconnected the crank position sensor, The two cam positions sensors are known as G1 & G2
34 probably indicative of the weight of your right foot![]()
just did my cam gear and now i have codes
i have a code 13 : RPM Signal, NE signal is not input to ECU for 50 msec. or more when engine speed is
1,000 rpm or more.
and a code 34: Turbocharging Pressure Signal, Abnormal over charge during high load
driving.
does that mean my map and cas are buggered
The boobs are back
it never saw more than 5-10 psi, where is the crank sensor
The boobs are back
timing cover around front of crank - see Rorge's thread as i think there's pics of the front of the engine.
load signal error could be that it think's it's at a lot lower rpm than is the case (e.g. i think i'm doing 300rpm so why do i have 5psi boost?).
I don't think you should have touched the CAS if changing cam gear? I would just check all the wires are as normal. Infact, from looking at my engine I don't think I would have to unplug any wires to install cam gear.
i didnt unplug anywires, but i must've fucked with something
is the cas just near the timing belt tensioner
The boobs are back
the cas is the one just near the timing belt, i had to move the wires a bit to get at the tensioner, so i gave them a wiggle, have reset the ecu and will try again
fucking car
The boobs are back
think i fixed it, both cams were out by 1 tooth
The boobs are back
Originally Posted by MR DOHC
Are you going to apoligise to it?Originally Posted by MR DOHC
i will make passionate love to it for 25 seconds
The boobs are back
jeez - that's pretty long for a guy
definately fixed now, sorry chris, cant rep u, need to spread more love first
The boobs are back
