i used silicon to seal up the soarer's lenses, with a bit of window cleaner i was able to make the bead of silicon reasonably fine and moulded, but in general didn't look very 'factory'
luckily it was in an area that doesn't get seen so it wasn't really an issue. if that is an area that is seen, i would recommend you be very careful how you bead the silicon and still have it look neat.
on a side note though, if the need to take it apart again arises later on down the track, i'd still like to be able to separate them again.
