You have to split the case apart and slide the extension housing off.
You will then beable to remove the internal selector rod from its shaft by undoing the bolt and swap it over to the shorter rod to suit the mid mount shifter.
Make sure the box is in neutral when you pull it apart..
Extension housing is the same and doesnt need changing.
