no(10char)
Done the search, nothing under the combinations I'm trying, Got a 1JZ R154 bellhousing/ flywheel /clutch.
question;Will a w58 bolt up to it?
no(10char)
Destroyer of 'Drop Forged' spanners
clutch is different and so is bellhousing. not sure on flywheel, i know there 240mm but unsure if the pressure plate bolts on.
use a jza80 N/A bell
As said, none of the 1jz -> R154 stuff will work in a 1jz->W5x application.Originally Posted by The Real Roadrunner
The bellhousing is wrong, the clutch, pressure plate and flywheel are different (the W5x pressure plate doesn't bolt to the 1j->R154 flywheel without mods).
As said get a 2jzge -> w5x bellhousing and bits
Or even better, get an R154.![]()
Norbie!
www.norbie.net
If you go the W58 route, I'll buy the JZ/R154 bellhousing off ya![]()
Thanks,(MKiii, I know it's useless rubbish,but I'll leave it all in the garage for a while,price of alloy scrap might go up.![]()
lol - ok
PM me if you change your mind![]()
go to toyota and buy a new bellhousing from an is300 2jzge lexus it will bolt straight on cost about $300 and is lighter and better fit that the likes of a dellow or similar
anything second hand will be as rare as rocking horse shit mate
a fool remains undescovered untill he speaks!
Has anyone got a part number for the 1jz-w58 bell housing??
N/A 3SGE KE70 on its way
Changed your mind yet?![]()
Weren't all the IS300s auto with the A340e?Originally Posted by 1jzracing
Manual IS300's existed in the US, don't think they landed here though? In any case you should be able to order one no worries if you have the part number.
Norbie!
www.norbie.net
True true. Ill have to enquire.
Edit: enquiry made.
NoOriginally Posted by Mkiii
,and as long as I am running a1JZ will be hanging onto it, bought it so I could drop of the auto ASAP, but now find the combination of auto andVvt is like a turbine, love it, but when the auto dies, a 154 goes in.( I didn't realise the bell was the hard part to find)
