Results 1 to 15 of 28
Thread: Engine oil temperature
    Default Engine oil temperature
    What is the ideal operating temperature for engine oil? I've recently installed an oil cooler and an oil temp gauge, and after driving for about half an hour last night (admittedly it was cold) the gauge never got far above the minimum which is 140 degrees F, I think at one point it got up to 150. Is that too cold? At the moment I don't have an oil bypass thermostat and I'm thinking that might be a problem.
    no backyard Domestic Engineer japlish's Avatar
    Default Re: Engine oil temperature
    i think the normal operating temperatures are around the 80-90 degrees C, 120 is the absolute max.
    yeah i've wondered this as well. as my exhaust on my 162 at the moment is pretty much resting on my sump. it might help the oil warm up and thin out quicker but not sure if its gonna make things to hot.
    Quote Originally Posted by japlish
    Hmmm 140F is approx 60C, sounds like it's running too cold.
    A guy i know on these forums had a similar problem on his starlet. He installed an oil cooler and guage and just like you his guage wouldnt even register unles you slightly covered the cooler.
    The real problem lies in that the cooler is probably too efficient in the temps we've been having recently but when summer rolls around the cooler will probably get the oil alot closer to the desired range. You could opt for a smaller cooler but it will probably not work as well in summer at keeping you in the desired range so your best option is probably the thermostat.
    Yeah I already have a small cooler, I don't think they get much smaller and even if they did it would kind of defeat the purpose! Bypass thermostat it is.
    Where is the sensor for the oil temp located?
    You might be right thinking that the thermostat for the bypass is a bit funny. Well at least thats what my unedumacated guess is.
    ...... butt scratcher?!
    Karl - he said he didn't have a thermostat nothing funny about it
    Norbie - use a thermostat
    Mos.
    Well then - my thoughts about the thermostat being funny were right! There is no thermostat.
    I mis-read the first post and thought he said he DID have a thermostat. I am retard.
    Sensor is located in the oil filter adapter, and if I got it right it should be located before the cooler.
    Keith (MonkeyMagic) runs a cooler out the front of his sprinter - without a thermostat he resorted to a removable metal plate in front of it for street use and at QR he removed plate.
    Jun 2007
    Maximum temperature depends on the Oil Weight used...... and whether it is Ester-based or not.
    But for all types, 110 Deg Celsius is a safe Maximum.
    Also having the Oil too cold robs power........
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    Yup I have always been again oil cooler kits with no thermostat! I personally think they do more harm tehn good on a road car...
    But then again its probably a lot colder where I live!
    I run a Mocal thermostat take off plate on my car, it flows a tiny amount even when cold to keep the cooler purged and air lock free, then opens it up fully at 80 degrees C. I also removed the factory water jacket cooler...
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    Perma Cool Make a good oil thermostat, about $85. The temp setpoint is 82deg C (180deg F). http://perma-cool.com/Catalog/Cat_page14.html
    Current Cars:
    Junior Member Grease Monkey off-road's Avatar
    NT
    I would locate it after the cooler so you are reading the actual oil temp the motor is receiving.
  1. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  2. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  3. MA70 --> JZA70 Conversion
  4. my masochist engine swap... 3S to RWD
    By Roman in forum Engine & Driveline Conversions
    Last Post: 10-04-2007, 10:22 PM
