Results 1 to 7 of 7
Thread: gz10 ajustable coilovers
    club outrun 1st year Apprentice
    mildura
    Default gz10 ajustable coilovers
    hey i was just courious what has to be done to fit ajustable coilovers into the front of a gz10 soarer, im pretty sure the ma61 supra has the same suspention setup.
    just gathering info and prices to see what options i have.
    Junior Member Grease Monkey Beserker99's Avatar
    Default Re: gz10 ajustable coilovers
    As far as I knows, you need.
    - Coil over sleeve kit (koni sleeves are well known and widely used)
    - Smaller diametre coilover spring
    That's about it..unless ya want cambertops or a shorter stroke shock insert Then..
    - Camber tops
    - Shorter stroke shock insert (or shock spacer if you don't want to cut down the strut body)
    - RCA (for shortened strut body)
    I think that's is. Feel free to add anything I've missed. I'm only posting general idea of it all, and not into anything specific.
    You can either modify your existing struts with coilover sleeves (as described above) or adapt a coilover setup from a different vehicle. I did the latter using JZX81 Chaser coilovers (see my web site for details), I think others have used S13 coilovers.
    mildura
    so what ur saying is u can just buy these sleves off the shelf from koni..
    Yes, you can buy the sleeves off the shelf...
    http://www.importbitz.com.au/koni.htm
    mildura
    cheers guys thats about all is needed to know
    ill keep you posted on what i do
    Yeah..from what I remember the koni sleeve was approx $240 for the pair.
  1. S13 Coilovers Into RA65?
    By Hibino in forum Tech and Conversions
    Last Post: 04-06-2007, 10:23 AM
