The main error is that you didn't grind off the NISSAN on the calipers before you painted them...(I know that grinding calipers is generally "Bad m'kay", but in this case, they are able to be ground off safely...)
^^^^^^^^^^^^^i agree with takai on this one
DS2500's are one of the best street pads money can buy (and still great for mild track use)
when it comes to brake parts dont skimp on inferior products.
linden
Tak, those pads are not EBC Greenstuff but original spec Nissan pads from Japan. Don't know why they were painted green, as the other set I have are blue. But both sets are definitiely Jap-spec Nissan pads.Originally Posted by takai
I'll see how they feel first up and, if worse comes to worse, I'll invest in some new ones, as you and Linden suggest.
Peter
Nah, I couldn't bring myself to do that. I know it might upset a few ppl but I quite like the Nissan logo through the wheels.Originally Posted by twentyEight
On the other hand, Tak's look quite good in red.
Peter
i had planned on using these callipers in one iteration of a brake upgrade, (like most of them, it never got past a plan) but instead of shaving off the "NISSAN" logo... just shave off "NI" and "AN" leaving the "SS" . i reckon it would raise a few eyebrows,
'77 RA28LT #2 ← 2.2L 18RG...
nice writeup, whens the conversion kit come up for sale, or just the hub spacer is really all i need, or a seperate pic of the spacer would be tops, as i cant quiet see what you mean (ive got the dumb tonight
thanks.
As above.Originally Posted by takai
Thanks!
Andrew
hi peter,
do you think these would fit under the front of a classic celica? i think this maybe what in_05_nt is heading to next, currently as you know ive got the hilux rear diff (will deposit cash into your account for the ma70 bracket tomorrow) so i have a 5 stud pattern and would like the same on the front with some bigger brakes
+rep again this is a great writeup
thanks
craig
ummm i think you meen 8mm, and the spacers should be 30mm wide also to stop the caliper flexing.Originally Posted by infotechplus
linden
Oops. Thanks Linden. You are absolutely right.Originally Posted by The Real Roadrunner
8mm it definitely is.
Peter
OK. I have some demo brackets for the Nissan front conversion.
These are a mm or so smaller than the specified dimensions but still usable.
I'll be test fitting these on the weekend.
I know one is much narrower than the others but these are only test units and spares.
Peter
i used single spacers welded on with my ma70-hilux diff brakesOriginally Posted by Herus
THE OFFICIAL TOYMODS BOGAN
MA61 - sunroof., 7MGTE, 4.11 lsd, w58
MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
I just thought I would let you know these are R33 GTSt calipers.Originally Posted by infotechplus
R32 GTR are almost the same looking
I believe there is no difference between R32 GTR and R33 GTS-T calipers...
R32 GTS-T calipers however, are almost the same looking...
Here is a bit of info for all you guys!
R32 GTSt
Suits 280x30mm disc, has ribs on casting, same as Z32 300ZX?
R32 GTR
Suits 296x32mm disc, has dip in casting above the 'SS', 2 half moon cut outs on outer edge, they don't have the raised bit under the 'Nissan', may have slight difference in mount offset compared to R33 GTSt due to different disc height.
R33 GTSt
Suits 296x30mm disc, smooth casting, straight above the 'SS', looks same as R34 GTt.
R34 GTt
Suits 310x30mm disc, smooth casting, same looking as R33 GTSt but longer mounts.
Hope this helps!
