What pistons did you plan to use for your overbore? 18R-G pistons? or custom or forged pistons? If you're going so far as to get pistons made up to suit a substantial overbore, the work required to ensure they clear the appropriate valves is going to be insignificant by comparison.
If you use the 70mm crank your rod to stroke ratio would be pretty good but the engine would be all top end with no healthy midrange delivery, you'd consequently need to wring its neck to extract it's potential and hence would need to prepare the bottom end appropriately for such abuse.
In another thread Rodger from Canberra mentioned using 44PHH Mikunis on a single cam 2T motor at approx +1mm overbore on 70mm crank for approx 1615cc displacement and turning approx 75rwkw at 7000+rpm. for that output i presume he had some long duration high lift cams and some good static compression.
