Results 31 to 45 of 56
Thread: The Themofan Switch Adaptor Thread - With superawesomeness Speco Adaptor Stuff.
    Default Re: The Themofan Switch Adaptor Thread - With superawesomeness Speco Adaptor Stuff.
    good stuff guys thanks for the extra references, this is what toymods is all about, +rep has been sent
    Hoppers Crossing
    bugger. you must spread more rep around before giving it to rob.
    good work with the spaco thomarse part numbers dude.
    how about using a DAVIES CRAIG thermo switch? adjustable, so you can set it to your temp,
    just slip the brass sender in the top hose...... $80 from autone/repco,
    blake
    Because they are junk and leak
    haha i tried to type up a post trying to articulate this in the nicest manner but gave up
    i had mine in there for over 2years, not one leak,...you just have to make a rubber seal betewwn the wire's,
    and looks hell neater than those chunky switch blocks, hacked into the middle of a hose
    plus its adjustable
    Hoppers Crossing
    they're a bugger to get to not leak though.
    plus you've all the copper capilliary wire floating around and hard to make neat
    upside is adjustable and very handy
  8. #38
    Or not...
  9. #39
    [Borat voice] NOT [/Borat voice]
    Quote Originally Posted by rob
    well said
    Much easier when you can only type one handed now.
  11. #41
    Quite a few years ago I had a 180sx with an RB20DET (Boo Hiss). To control the thermo fans I had a boss welded into the thermostat housing. I had this done at ARE and they also supplied a temperature switch, from memory it was a relatively low temp switch due to it being in there. It ended up looking very neat due to being tucked away.
  12. #42
    Quote Originally Posted by omp
    ....now thats a neater idea,
  13. #43
    Yeah, sorry, no
    The chunky switch block tucked away in the bottom hose is usually hard to see and will only have a small amount actually visible outside the hose.
    The extremely ugly and big and poo thermostats are something like 30's oven technology that, while possibly reliably simple, are far from an advanced or elegant solution.
    Everything is about compromises and the inline switch fitting is, IMO, a much better compromise. (If you don't want to compromise get one fitted to the bottom of the radiator).
    Mos.
  14. #44
    nah, i'll just have mine controlled by the SM4,
    blake
  15. #45
    Hoppers Crossing
    or ; in the old school radiators ; have a boss brazed into one of the tanks...
  1. 1jz temp switch
    By naten in forum Tech and Conversions
    Last Post: 01-06-2010, 04:28 AM
  2. 1jz to 2jz
  3. reversing light switch W50 Location?
    By normo in forum Tech and Conversions
    Last Post: 11-09-2006, 08:44 PM
  4. One for the electronics guru's
    By BradW in forum Tech and Conversions
    Last Post: 01-08-2006, 12:01 AM
  5. Stuck oil pressure switch 3tg
    By MarioM in forum Tech and Conversions
    Last Post: 11-02-2006, 04:47 PM
