Results 16 to 18 of 18
Thread: Spluttering, then stalling when accelerator is touched
    Jun 2006
    Default Re: Spluttering, then stalling when accelerator is touched
    I know its a mr2 3s but a turbo pipe came loose and it did similar things,started ok and idled but as soon as you moved the throttle it started to die badly and stalled not long after.
    If its kind of AFM related you might have a leak somewhere between the afm too intake manifold gasket to block.
    who said you couldnt make a ae86 rear quarter outa bog,fibreglass and expanding foam!!
    Apr 2007
    queensland
    my ra23 does this when its cold. have let it warm up, and its good, have been told its the ecu settings.
    if you've had to change the radiator fluid to put the chemi-weld in then this could be the problem..
    assuming your VL has a rb30 in it. you can get airlocks in the coolant galleries when you change fluids which could overheat and give you a warped head, which is common for the VL rather than in the rb30 running skylines as the radiator is situated a tad higher in the skyline (from what i've been told).
    my 5cents.
    good luck. hopefully your problems aren't too drastic
  1. 4AGZE AE-101 Stalling With FMIC
    By dave_101 in forum Tech and Conversions
    Last Post: 01-02-2007, 10:13 PM
  2. Fixing your stalling 4A-C Engine
    Last Post: 18-09-2006, 08:23 PM
