Results 16 to 30 of 41
Thread: Paint on turbos?
    Western Aus
    Default Re: Paint on turbos?
    Quote Originally Posted by Ben Wilson
    I don't think the housing will get as hot as the turbine wheel.
    Engine enamel wouldn't stand a chance on extractors, let alone a turbocharger.
    You might be able to get away with VHT, you need a spotlessly clean surface and several light coats. It's even better if you get the metal hot before you spray the final coats - If you don't have an oxy, getting it hot on the car works. I'll leave the masking up to you to work out, I'd suggest alfoil might be the go.
    Ben, i was referring to VHT engine enamel.
    AFAIK the VHT stuff is rated the same temp as the other brand i saw, cant remember the name.
    wasnt aware there were heaps of companies making the same thing.
    Elmo.
    on a turbo, HPC ftw.
    on extractors, HPC also...
    my 4G54 (2.6L Astron) out of my old Scorpion, headers removed, prepared and painted up in the manner that Ben has suggested above (was a hot day also, headers were hot when final sprayed), and after just 10 minutes going for a run in the car, I pop the bonnet to find all the good work and my bright red VHT (1500*) scalded and turned a frosty white colour instead. thus why I don't trust VHT anymore.
    TRIKKE | Video
    Western Aus
    that looks good though!!!!
    wicked!
    Elmo.
    HPC coating works OK on turbine housings, but if you get silver dont expect it to stay shiny for long! On the plus side it does stop them going horrible brown rusty looking
    wicked!
    Elmo.
    hrmm, well... I couldn't understand why it left some areas the original red colour (around the flanges, the Genie badge, etc.) and turned the rest white though. still got me stuffed.
    TRIKKE | Video
    Junior Member Grease Monkey Adrian's Avatar
    Apr 2007
    W.A
    Quote Originally Posted by RObErT_RaTh
    Thankyou
    And thanks again
    Off to the shops on the weekend it is
    No worries, anytime.
    Montrose
    If you drive your turbo car like you know you should, then the manifold, turbine and first part of the exhaust all glow a lovely red colour. Nothing that costs a few dollars and comes in a rattlecan will put up with that too well. I got my headers back from HPC the other day and they look SO much better than before - plus another set that I've been using for almost 18 months now still look all nice and shiny. Another thing is, the ceramic coating's thermal insulation claims do seem to work, from the things I've had done anyway. Having said that, some exhaust paints do survive, well a least a bit of a distance from the engine they do anyway!
    Western Aus
    heat? or maybe it was really hot, and the white areas copped cool air and it cooled down too quick? who knows.
    its christmas in that engine bay!
    Elmo.
    yeah could have been, but I guess I'll never really know...
    Christmas in my engine bay? yay fat Santa, drop in beside my engine and gift me a Garrett turbo w/ 3" system in place of my Genie extractors... ho ho fcuking ho.
    TRIKKE | Video
    Western Aus
    Quote Originally Posted by mrshin
    cheers for the info, if someone in perth can do HPC coating, ill be sure to consider getting it done if i can afford it.
    also, ive had the 1J for 7 months now, and i havent managed to get it anywhere near red-hot at any stage, and ill let other people confirm, the turbos get a hefty workout.
    i also run no heat shield (i think it looks like shit) and i still havent noticed any probs without it.
    Elmo.
    Elmo.
    Do you have an underbonnet camera to confirm this?
    I've had my turbo on my stock 7M glowing after a few hours driving on the highway. Boost was always at 0 or 1/2psi.
    Western Aus
    no, but i have underbonnet looking abilities, called looking while the bonnets up.
    i dont stop, open my door, leisurely stroll around to the front of the bonnet, forget i havent opened it from the cabin yet, stroll back around, pop it, then repeat
    i wouldnt expect the 5 or so seconds it takes for me to get out and pop the bonnet after a hard run would be enough to lose enough temp to drop down from a red-hot temperature?
    Elmo.
    No, but slowing to a stop might be enough time, unless of course you roll to a stop slipping your clutch at 9000rpm
    Ive got HPC matt black on my exhaust housing, looks like a brand new turbo.
    And a Hpc silver coatin on the front cover, although youd think normal hi temp paint would be more than enough for a front cover.
  1. Turbos 101
  2. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 02:09 PM
