Results 16 to 27 of 27
Thread: removing head, 3sgte gt4
    Default Re: removing head, 3sgte gt4
    danny I had a full ST205 setup on my RAV4 and I was lucky enough to find it when I did... just not lucky with it's condition. since RAV4's and GT-Four's share the same drivetrain setup, it was a bit of a double-edged sword with putting in a GT-Four engine. It mounted up beautifully with engine mounts and gearbox, but if you ever had to work on it, get ready to rip stuff out, undo the exhaust, crossmembers and engine mounts from the chassis, and drop the bitch right out. it was WAY easier to work on everything with the engine completely out of the bay, albeit the gearbox came for the ride too. that's a big disadvantage with the GT-Four... if anything happens in the guts of the engine, it's ALL gotta come out.
    TRIKKE | Video
    Apr 2007
    went to see my trusted engine rebuild shop today and i was told that bhg is very common with these engines and to leave the car overnight and crank it over with the plugs out and some cardboard over the holes to see if there is any water in the cylinders.. told me number 1 or 4 are likely to go because of the water galleries corroding.. also he sai d that i was better off leaving the engine in when i take the head off.. quite a contrast to you guys, i doubt he has done it before lately..
    i was also wondering how you would retension the head as you have to pull the cams off to get the the head bolts
    also thinking about the possibility of putting in a gen 3, but from what iv'e read wiring is quite a lot different to gen 2.. anyone done this before ??
    you don't retension the head bolts on this engine. do it once to the required spec and then leave it. people will say that you have to retension them after a rebuild, but if you have decent stuff in there like ARP or similar, you won't need to worry about it. this has been mentioned on a few other threads as well.
    not 100% sure on the wiring between gen's 2 & 3.
    TRIKKE | Video
    thats true ^ if you do it right you wont need to retension them, i had my HG and head done on my old 3sgte, didnt require a retension and was fine.
    i found when mine was done, i bought a VRS kit from toyota, and a stainless steel HG for it and it loved it ! also its best to remove it all at once take the head out and get it machined.. just while your at it, its a Kent doing it all, the 3sgte is such a jam packed motor.
    thats one thing i dont miss about them, is how much of a PITA they are.
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Olde ****** Automotive Encyclopaedia ToDa30/4's Avatar
    south australia
    Quote Originally Posted by danny2
    danny drop it out to work on it if needed ,most of the answers you seek are in the GT4 thread m8 . you have some very learned GT4 folks in the ACT that use the forum .they could give you advice on the spot if u ask nice
    Project ST215W 300 AWKW Killerwagg'ss .staring in the garage .soon
    ST185R 385 AWKW now SOLD ..Daily '89 Eunos Roadster.
    Project '75 KE30 37.4 RwKw PIMPster. doing it for Angela RIP 1964 - 2011
    has no Toyota anymore :( Conversion King tooch's Avatar
    Actually, I'm gonna disagree with you guys sorry, but it's highly recommended that ARP bolts are retensioned after a couple thousand km's. I cant remember exactly why, but I've read from many sources that you should do it.
    As for removing the cams, I'm fairly certain you can get to the Gen 2 3S's head bolts without removing the cams, as long as your hex driver thing is low profile enough to fit. From memory (a little fuzzy ), there is a 'notch' on the cams to allow you to get to a couple of the bolts.
    Western Aus
    Quote Originally Posted by Dale
    I read your other thread and all I can say is I certainly wouldn't rush into removing the head right away - as said they'd be ridiculously hard to do with the engine in the bay, the lean the motor is on doesn't assist either. Get a TK test done to see if your HG is gone
    If it comes to having to do the head gasket, pulling the lot out isn't overly hard, make sure you drain the diff oil as well as the gearbox oil else you'll get a nice surprise when you pull the tailshaft out if it's all coming out just a tip that the gearboxes in these are real fucking big and heavy, there was 5 people once all helping out when we refitted one to the engine
    TK tests are poo
    if you fail, you have BHG
    if you pass, you may still have BHG.
    mine passed 5 different testings (by 3 different mechanics) and the HG turned out to be leaking in 11 places.
    Elmo.
    i only had the standard head bolts ?
    do you no if that applys to all bolts or just ARP ?
    Mmmm Bickies Domestic Engineer GriZZly's Avatar
    Is a TK test the same as a CO2 test? thats what confirmed my BHG..
    ARP recommends "retentioning where necessary", no idea what toyota recommends for stock bolts.
    Also i took my head off 3 weeks ago, theres no need to take the cams out while the head is on the block you can access all the bolts with cams still in..
    As tooch said the intake manifold supports can be a pain in the ass but fortuneately theres only 2 with 1 bolt each ratchet spanner would help out alot there..
    Timing belt took 3 hours or so to come off..
    Havent put it all back on yet so cant help you there.. will keep you posted if want, wont be going on for another 10 days or so though..
    GT4 Freak, and Conversion King Squid's Avatar
    danny - pm me and I'll see if I can help, I don't know it all, by any means, but I have pulled out a couple of motors...
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    south australia
    Tooch ,id like to see the threads regarding head bolts ,Miltons said my ARP studs did not need re tensioning on the 3s gte when i had the big rebuild , followed by worry . squid all rep to u for helpen out
    toda i can email you a pic of the instructions.. basically just says retighten where necessary..
    guess it cant hurt to take off the cam cover to check..
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 10:33 PM
  2. 3sgte head gasket worries
    By milosamun in forum Tech and Conversions
    Last Post: 27-03-2007, 03:13 PM
  3. How do i change the head gasket in my 3sgte
    By millsi in forum Tech and Conversions
    Last Post: 12-07-2006, 03:06 PM
  4. Oil pipe on gen3 3sgte head
    Last Post: 31-10-2005, 01:08 PM
