just run it off the coil pulse
how can i test to see why my tacho is not working i have a spare tacho what wires should i check on coil or alternator i just want to be able to test without taking dash out i know my spare works and old one worked before i painted the face white pls any ideas will be appreciated
running your other tacho off the coil won't tell you why the factory one isn't working.
Is it the stock engine? check the wiring behind the instrument cluster.
oh sorry i thought he wanted to check the accuracy,
you sorry mate that instrument cluster is coming out
Before you start, check on your coil that there is a wire connected to the negative of the coil. This is the wire that connects up to your dash's tachometer.
fonzy
deepdishfactory
