Results 1 to 8 of 8
Thread: Apexi power FC
    Default Apexi power FC
    Hey guys
    just wondering if any of you will know if the Apexi Power FC will support VVTi
    I have one now for my sprinter, running the 16V
    planning on doing the 20V conversion, but just wanted to know if it will support the quad throttle and the VVTi
    if not, damn, have to bin this thing.
    cheers.
    Default Re: Apexi power FC
    Power FCs tend to be purpose built for the applicable engine so they can act as much as a plug and play item as possible. If it's designed for the 16V I doubt it will work for the 20V but others may know better than I.
    Junior Member Backyard Mechanic sw20r's Avatar
    If its for a 20v, I highly doubt there was a power fc 20v revision.. There was a limited release of the official Power FC list for Toyota.
    If your lucky you mind find an A.P Engineering version for the AE101,AE111
    Hurry up if you want a power fc though! as they are really rare these days esp for Toyota.
    The one that I can find is the AE101 BT - http://cgi.ebay.com/ebaymotors/Apexi...5699QQtcZphoto
    The only PFC models ive seen are the AP engineering AE86 4AG kit. and Possibly the brashboy pfc's
    http://cgi.ebay.com/Apexi-AP-E-Power...QQcmdZViewItem
    [update]
    I've found the AE101 afm removal kit by brash boy
    http://www.brashboy.net/english/toyo...ex_toyota.html
    Note these ecu's are tuned already. and if your going to get the brash boy then you might need to get a map sensor addon or re-wire your afm into an air temp sensor like i've done on my 3SGTE.
    If your power fc is complete like the kit above you can probably sell it off
    Mine is the AP enginnering one.
    The Power FC kit for AE86.
    so does do you reckon this will work with a 20V as well?
    Jan 2012
    I have an unused A'pexi Power FC for the 1JZ VVTi (Soarer '97 + and Chaser) together with Commander - available 'cos I installed an Adaptronics ECU instead.....PM me at burrettpeter0@gmail if you're interested......like rocking horse pooh, it's rare and not cheap.....regards Peter Burrett
    the jzx100 and jzz30 vvti powerfc's are readily available and cheap brand new, they even have a djetro version now with EL hand controller.
    Jan 2012
    Question Re: Apexi power FC
    Quote Originally Posted by JP View Post
    the jzx100 and jzz30 vvti powerfc's are readily available and cheap brand new.......
    So you say, but where? Every where I look they are out of stock and show as discontinued. By the by, mine is new, still in original boxes, never installed....Regards Peter Burrett
    ebay, nengun, streeter etc. They're not discontinued and very easy to get...
    eg:
    http://www.ebay.com.au/sch/i.html?_n....c0.m270.l1313
    http://www.nengun.com/apexi/power-fc...and-controller
  1. 5ME - no power ( less than usual :oP )
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 30-08-2006, 09:27 PM
  2. Article: BHP vs HP vs kW and other power conversions
    Last Post: 07-06-2006, 12:37 AM
  3. Article: Torque / Work / Power
    Last Post: 02-06-2006, 02:03 PM
