Results 16 to 28 of 28
Thread: 7age blacktop..vvti possible??
    Junior Member Carport Converter Mooro's Avatar
    Tasmania
    Default Re: 7age blacktop..vvti possible??
    Actually thinking about that more, the increase in CR from the silvertop to blacktop 4age should stay the same with the 7age right...cos both the pistons and head are being used??
    THe silver top 4age is 10.5:1 and blacktop 4age is 11:1 so would it stand to reason that if the silvertop 7age with 4a HG is 11.35:1 then the blacktop 7age with 4a HG should be in the vicinity of 11.85:1????
    Quote Originally Posted by Mooro
    Yep... I sent you some mail too.
    New Zealand
    With the BT the higher CR is achieved via the pistons right? as opposed to the silvertop where it is the combustion chamber,
    pistons AND combustion chamber are different between the 2.
    what thickness do you have for the 7afe gasket? your getting quite a lot of difference in compression there
    please, no more PMs!
    Tasmania
    I think the 7a HG is 0.6mm vs 1.2mm for the 4a one, so quite a bit of difference. I'm just quoting what I have read in other threads though, so it is not gospel.
    Thanks for the email Johnny, I get what you mean with the cam timing, in that you are basically lowering the dynamic compression even though the static compression is the same...but are there any other issues associated with altering the cam timing in this way or is it just the same as running the engine with a slightly lower static compression ratio?
    Feb 2007
    Timaru
    What was the figure you used as the CC of a silvertop head?
    I worked mine out on a BT, as I have one of them on the bench,
    but dont want to pull the Silvertop head off my race car just to measure the CC.
    I want to work out what the comp ratio is with 8.9 GZE pistons, a silvertop head, and a 1.2 mm gasket, and the ST head CC is the only number i'm missing.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Quote Originally Posted by DX20VT
    I'm pretty sure it's 36cc's, though that'd need to be confirmed.
    www.billzilla.org
    Toymods founding member #3
    Quote Originally Posted by Billzilla
    We work on 36-37cc, Though when measured it was closer to 36cc, so your not far out Bill
    Feb 2007
    Timaru
    Quote Originally Posted by johnny
    I measured the BT to be 38cc, does that sound about right?
    - KE70 Corolla Dx -
    Tasmania
    So has anyone done the math to know the exact CR with blacktop 7age using 4age gasket?
    I'm not exactly sure how to check it. I've found another potential BT halfcut but it's in Sydney !
    Feb 2007
    Timaru
    From my own measurements and workings out,
    ( which may or may not be correct)
    7A with AE101 8.9 GZE pistons, Std 20V 1.2mm head gasket and BT head is 9.07:1
    7A with AE101 8.9 GZE pistons, Std 20V 1.2mm head gasket and ST head is 9.37:1
    - KE70 Corolla Dx -
    Junior Member Backyard Mechanic Dimitri's Avatar
    didnt see it noted anywhere here, but 2 things.
    the chamber and piston crown is a different shape in the bt, with different squish areas (basically none on the bt)
    the bt cam tooth profile is different to st. st profile the same as 16v.
    so to use the camira/porsche/16v 4age belt, you need the correct pulleys on your bt.
    Feb 2007
    Timaru
    Can't say I've noticed a difference,
    I run a 20V Silvertop cam drive, and 20V Blacktop cam wheels and a 16V smallport cambelt.
    - KE70 Corolla Dx -
    well go look
  1. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 11:31 PM
  2. 1jzgte vvti into mz20
    By JZA20 in forum Tech and Conversions
    Last Post: 23-07-2006, 07:14 PM
  3. 2JZ-gte - interference details and random vvti info
    By Draven in forum Tech and Conversions
    Last Post: 18-06-2006, 08:06 PM
  4. 20v vvti
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 15-10-2005, 07:29 PM
