Results 1 to 6 of 6
Thread: Q: Coil & igniter for 1GGE gen2
    south austraila
    Default Q: Coil & igniter for 1GGE gen2
    I have a Gen 2, 1G-GE, map sensor motor with T-vis, with no coil & igniter
    Is there any other motors i can use one from
    i have looked at 5M-GE with a two wire igniter, it also has the same color wires. can this be used ? or will only 1G-GE do ...
    Dose some one have the, id.numbers or codes
    any help is good, thank's
    Project: '82, GA61 XX
    Junior Member Domestic Engineer mic*'s Avatar
    Default Re: Q: Coil & igniter for 1GGE gen2
    Mate if it clips up it may well work.
    I had ignition probs with my GZE. In mucking around i found that the waste spark 7MGTE igniter is the same as the 1GGZE apart from the sticker & part numbers on the front.
    You wont hurt the ECU trying the igniter.
    meh...
    south austraila
    Some one has done some shitty work on the loom i have
    so i'm doing a rewire Hence No plugs..
    I have looked at both the 5MGE & 1GGE ECU's, & the components on the boards are slightly differant..
    being only a two wire system, one would think they would be the same.
    south austraila
    Bump....
    Has anyone, got any pic's , part numbers, or info, for a 1GGE Gen2 igniter
    or has anyone got one for sale
    The trigger sense to the igniter from ECU will be low voltage - like 5V, on either one.
    The coil matches the igniter.
    Either the dwell will be right or it wont. Try it & measure the dwell.
    meh...
    south austraila
    This must be an odd motor, as knowone seems to be able to help, with pic's or details.
    But will be trying what i has got..
  1. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 01:29 AM
  2. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 07:52 PM
