yeah but if i had figured on the front diff i would have sourced a front sump . this sump had to be severely modified.but it works fine with no leaks but holds 400ml less oil. cheers bigwad
is that a rear sump?
This is Awsome!
Id love to hear about how you did the transfer case. to keep 4WD. Id love to have a 1jz hilux, I though it would end up having to be 2wd, as I have no chance of making an adaption between the two.
Congrats on the awsome work.
HZJ75, RS41, JZZ30
				didn,t have to do anything to the transfer .i used a reco std g52 hilux box .i bought a blank cast bellhousing off pete jacobs, drilled all the holes to suit the box and engine, fitted the original slave cyl and clutch fork then fitted the lot using the std box mounts to get it all positioned then made the engine mounts to suit.i wish i had known all this before i started caus it would have saved 6 months and alot of $ and head scratching .go for it, a wicked conversion. cheers bigwad
Cool as. Im supprised that the G53 would handle the 1jz, and also bolt up with a different bell housing. I thought other things wouldnt line up.
Congrats.
HZJ75, RS41, JZZ30
				well to be honest if you try to drive them like a dragcar you will end up with a toothless input shaft, trust me.but i suppose if you get offa and start doing smokeys in second gear with a detroit locker and 33,s you are going to bust anything.a gutfull of turkey will always cost you more than the bottle did.i,m old enough to know better but why should you young blokes have all the fun.cheers bigwad
That's a great sayingOriginally Posted by big wad
Nice conversion. That makes 2 4wd 1jz conversions I have heard of now. The other one in the Bundera formerly owned by Skip using the R151 gearbox.
				have you any idea what a r151 gearbox came out of caus i rekon i,d be best be saving for one if they are stronger. cheers bigwad
toyota surf turbo diesel has the box you want
or ask NeoNasty as he has just read all about Skip's conversion on the old forums![]()
Yeeaaarrr
That there be true me hearties..
She blows from the Toyota surf and 4 runners. I believes.
Many a conversion has been done before using that box.
HZJ75, RS41, JZZ30
				thanks for that old boy, i,m going to keep an eye out for one of these boxes .i,ve just wacked a new input shaft and cluster in my old box for now and also a std flywheel and exedy clutch.. should be a smoother ride now. so the super single is on the market. cheers bigwad
				ok i just took the old girl for a run with a std 2jzge flywheel and exeddy clutch fitted . lost a bit of power but it is much nicer to drive ,the missus will be much happier. so the os super single is still for sale .its gotta be value for 500 bucks. cheers bigwad
				who did the wiring for you???????? please get back to me with all the info about it...
PM me on here or email to [email protected]
Power to the Luxes! Great to see another one on here
