Results 1 to 6 of 6
Thread: anyone with ke30/55 whos done the pug/rona conversion
    ****yas Grease Monkey
    western australia
    Default anyone with ke30/55 whos done the pug/rona conversion
    ay i've got my hands on a set of corona struts which need a new set of inserts and i was wondering what inserts and what springs to use. the car that they're going into is a ke55.
    i figure you still use standard corona inserts but im not positive. also, what springs do i use for it?
    the corona strut still has the standard spring perch on it, which i think needs to be replaced with the spring perch of whatever spring is going in??
    My Missus is a Domestic Engineer BradW's Avatar
    Default Re: anyone with ke30/55 whos done the pug/rona conversion
    PM cuzzo. He has this brake setup on his KE30. He has height adjustable coil overs on his.
    Brad
    Old Corollas never die...
    My KE30
    Quote Originally Posted by caibs
    The standard extended length of the KE30/55 and RT132 assemblies is pretty much the same. So you can use the standard RT132 insert if you want to maintain pretty much standard ride height.
    If you go down more than a couple of inches and you're having issues with the spring not staying captive at full droop, you can use a shorter insert with a spacer in the top of the strut tube under the gland nut, or alternatively shorten the strut to suit a shorter insert. I have heard of RAV 4 and SW20 rear inserts being used before but you need to do a bit of research with the Monroe catalogue and decide which one works best for your application.
    As for springs and spring seats I think the RT132 springs will not fit in the KE30 tower and would be too long perhaps anyway. At the very least you will need to change the spring seats and run narrower springs, for ready tunability and margin for error in spring choice I'd do what I have done and fit a pair of Koni coilover sleeves and hats which will allow you to buy generic spring pairs in a variety of lengths and rates and also helper or tender coils to keep the assembly captive under full extension.
    Hope this helps and is not too hard to understand.
    western australia
    thanks man i really apreciate the extent of your reply. i've done some thinking and head scratching and rang up a guy whos in the know and i'm thinking that if i do it i'll do it properly and bang some coilovers in there. so far i've been quoted abour $600 for a coilover setup and a further ~$340 or so for some koni inserts which is not bad at trade price i reckon. what i'm unsure about, is that i can get a set of monroe inserts for $150 thru work, i dont know if the bloke was just trying to sell me expensive koni's or if they're actually worth the extra cash money
    well konis arent the bees knees
    but dont get monroes!
    David
    Cusco camber tops available for all early mac strut
    western australia
    well i guess i'll have to not be a tightfisted**** and spend the extra on koni's then dont i!
  1. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  2. MA70 --> JZA70 Conversion
  3. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  4. Conversion decision!
    By twentyEight in forum Tech and Conversions
    Last Post: 30-10-2006, 07:35 PM
  5. Clarification of Technical FAQ and Conversion Threads
    By river in forum Toymods Car Club Membership and Feedback
    Last Post: 05-06-2006, 09:20 AM
