Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 166 to 180 of 181
Thread: xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
  1. #166
    Default Re: xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    Protex also do Z32 rebuild kits.
    $35-40 a caliper, depending on the discount you can get.
  2. #167
    You can get those rear MCX brake caliper kits from Race Brakes Sydney, thats the place i got mine from im pretty sure. About $35 posted i think.
  3. #168
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    sweet! thanks guys by any chance, does anyone have the part number for the protex rebuild kit for the z32 calipers handy?
    +rep given to all (except cruzida... gotta spread the love. it'll come eventually though)
  4. #169
    Protex - 210E-0011
  5. #170
    Forgot to say, you can buy Genuine Toyota rear caliper rebuild kits, they only cost about $60 but they are from Japan which sucks. I bought the MCX ones becuase i couldn't wait the 4-6 weeks delivery time. The Genuine kits contain everything, piston boots and seal, slider boots and bleed valve cap.
  6. #171
    Feb 2011
    sa
    hey is there any chance of rehosting these images?
    so if i run r33 298mm disks with z32 calipers this will increse track 16mm
    can i use ba rotors? and will these fit 15'' wheels? and aprox caliper petrusion?
    (ma61 struts)
    thanks
  7. #172
    Most pics rehosted.
    If I can find some more recent pics I'll upload them.
    As for your questions, R33 296mm discs NEED R33 calipers (likewise Z32 discs need Z32 calipers).
    Its the 324mm R33 GTR disc that can be used with a Z32 caliper.
    And yes, using any of the Nissan discs will increase track by 16mm
    There is another thread regarding using BA discs and R33 calipers.
    *some* 15" rims will fit over the R33/R33 or R33/BA combo's, but not many
    Z32/R33 calipers will protrude ~40mm (bit less, maybe 36mm) past the wheel mounting face (ie, not the discs face, but where the studs are)
  8. #173
    Feb 2011
    sa
    ah thanks mate exactally what i needed
    do you still make the rear dogbone brackets?
  9. #174
    Nah, I don't.
    I had them cnc'd, so they were about $250 a side.
  10. #175
    Mar 2011
    Wink Re: xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    Just wondering is their a twin or 4 pot caliper that will bolt onto the existing ra60 front strut without to much difficulty and not having to change everything.
    As I have only got my car back on road after 10 years after carrying out engine transplant. don't want it off for another 10 years. lol
    Or should I find a good performance pad and a set of of rda gold slotted and dimpled rotors.
    Any help would be appreiated
  11. #176
    Junior Member Domestic Engineer Viper's Avatar
    All the items listed in this thread will work on a RA60 strut.
    So get reading ;p
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
  12. #177
    Sorry to drag this thread up again but does anyone still make the rings and spacers?
  13. #178
    Nov 2007
    Tasmania
    Is it possible to rehosting images for the brake upgrade? I'm interested in seeing how the ring is fitted to the hub.
    Also does anybody know where to source Z32 30mm rotors with the extra bolt holes for 4 stud pattern locally? Like these ones:
    https://www.phase2motortrend.com/pro...-z32fbkr30.htm
  14. #179
    Breaker of Things 1st year Apprentice setsuna's Avatar
    Local to where mate? I have a set of discs and calipers still. Just need the spacer. Easily sorted, I might even still have the CAD drawings if you want to get it laser cut.
  15. #180
    Nov 2007
    Tasmania
    Just in Australia to save on postage. I see new Z32 30mm rotors drilled for both 4 and 5 stud on ebay US. Was wondering if DBA rotors come with 4 and 5 stud drilled as well.
    CAD drawings would be good. .stl file or I use Inventor and Solidworks.
    By The Witzl in forum FAQ
  2. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
