Results 16 to 25 of 25
Thread: 7mgte injectors on a 1ggte
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    Default Re: 7mgte injectors on a 1ggte
    So where are the resistor packs on a gen 1/2, and how neatly can they plug into a gen 3???
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    90 Millcrest st
    youd be better off just going down to ur local electronics shop and buying 6 10ohm resistors and wiring them into your injectors wires. Check out this site, thought it was an interesting read:
    http://www.lextreme.com/R&D%20Injector.htm
    I dunno ey Chris, the resistor pack is fairly small. I'd be grabbing a factory pack if it were me.
    90 Millcrest st
    this is true, if you can source one cheap. Which reminds me im wrecking a 7mge motor with the yellow injectors which would have the resistor packs also if anyone wants some...
    Western Aus
    wouldnt be too hard to wire said resistor in behind the glovebox/dash.
    that way you end up with everything looking factory, all you'd need would be pinouts, and some solder, just dont forget they're there
    Elmo.
    Oxfordshire
    Has anyone got pics of the said resistor pack? How does it wire in? I am asuming its not going to be straight plug and play anyway.
    Some kind of BMW
    ..::VVTi 1UZ-FE::..
    I have one in my engine bay still, the bolt is just rounded, so I haven't removed it
    90 Millcrest st
    is the injector resistor the one that looks like fuel pump resistor, only on the other side of the engine bay?
    Ya, little alloy box with fins and a plug coming out of it.
    Oxfordshire
    Does anyone have a pic, or experiance of retro fitting/connecting one? EFi managament is not my forte
    Some kind of BMW
    ..::VVTi 1UZ-FE::..
  1. 7mgte wiring diagram similiar to 1ggte?
    By rollsy in forum Tech and Conversions
    Last Post: 20-11-2006, 08:49 AM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
