Results 1 to 8 of 8
Thread: where to mount bosch coils?
    Conversion Master Grease Monkey Whiplash's Avatar
    wa
    Default where to mount bosch coils?
    just was wondering whats everyones thoughts on where to mount aftermarket bosch coils in the car. ive got an a70 supra with 1jz. just wanna see if theres any better ways to do it then others.
    just got my microtech so ill be installing soon. pics of the coils installed would be good as well.
    shanon
    Default Re: where to mount bosch coils?
    Have seen many ways, mine might not be best but it worked and has not caused trouble. Have seen some 'interesting' setups!
    Its no Supra or a 1J but you get the idea.
    It doesnt really matter, so long as there mounted solidly to something metal, try to keep them out of the water and heat as much as you can. In saying that mine are mounted to the block from factory.
    wa
    interesting i was actually thinking of mounting them to the top of the engine. above where they normally are. wat you guys recon. might have to cnc a bracket or something similar at school. see how i go
    Yep alot of people place them there, most that i have seen there are mounted ontop of a bracket to block a bit of direct heat, you could bend up some stainless or alloy easy enough, drill a few holes and bobs your aunty.
    I just mounted mine on a plate which I then soft mounted to the fire wall behind the engine.
    I didn't like the idea of mounting the coils straight on the engine. I though the vibration would kill them before time.
    south australia
    i just made a mounting bracket for mine today:
    this will bolt to the firewall seam where the complience plates are on my 86.
    (the bracket will be painted and made neat)
    wa
    Quote Originally Posted by Crazyracer
    yer i dont think its vibrations that will kill it. more heat and water. 2 problems the factory units have being in a valley they get pretty hot and crack. also water int too easy to get out so yer i dont think mounting on engine would pose much or a problem, could be wrong but haha.
    i was thinking of the firewall mounting but i dunno i think its all the high tension leads and stuff. there just so bulky haha.
  1. 89 4AGZE into '85 NA AW11 (engine mount problems) - SOLVED
    By Phildo in forum Tech and Conversions
    Last Post: 20-05-2007, 05:56 PM
  2. Engine mount dilema
    By HAVABEER in forum Tech and Conversions
    Last Post: 07-09-2006, 11:21 AM
  3. Injector flow figures website.
    Last Post: 27-03-2006, 11:00 AM
  4. Which coils?
    By Rallystanza in forum Tech and Conversions
    Last Post: 25-02-2006, 10:05 PM
