Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: water injection pre turbo
    Feb 2007
    Default water injection pre turbo
    has anyone tried water injection pre turbo??
    i have done it on rotary engines with great results, and im thinking of doin it for my 1ggte..
    has anyone tried it and how did they go.
    the setup that i used was a pumpless system using a airation nozzle(similar to a spraygun) it uses pressurised water and air pressure that mixes in the nozzle and is pumped infront of the turbo.the water tank is pressurised by boost and is switched on via a solenoid and hobbs switch.
    a friend of mine makes 580 odd rwhp with a 13b bridgeport at 21 psi on pump gas(i know its a rotary sorry guys), this is around 200hp more than normal
    i also tuned one on a mates one and made over 400rwhp at 18 psi with a very mild engine , i have found this to be a sort of insurance as rotarys are somewhat fragile as well as powerfull.
    using this simple pre turbo setup seems to be reliable and cost effective.Im just not sure what it does to a piston motor power wise and what people have experienced..
    life begins at 30 psi
    Default Re: water injection pre turbo
    I remember an article many years ago in a magazine about water injection/water spray kits running pre turbo, but I can't remember which magazine it was...
    After a bit of testing they removed the turbo for inspection and they found that the spray had in fact left lots of fine pitting on the compressor blades, and advised that over a longer period of time, this pitting would cause quite alot of damage to the compressor blades and water injection/water spray kits running pre turbo should be avoided...
    ([][][]II--LT--II[][][])
    Feb 2007
    Quote Originally Posted by twentyEight
    i have seen this once before but the setup was a not that good and they had a washer bottle feeding ditectly in and there was no means for the water to atomise..
    i have witnesed a setup on a car that has done over 15000ks and no turbo damage at all, the secret is in the amount of water and the atomisation, the benifits i have seen with my own eyes . The amazing thing is after reading the plugs and looking at egts it seems as if the engine was running standard boost, we also ran more timing than normal .
    Ok, well I saw the same article TwentyEIght did...
    SO,
    You go ahead and run your turbo with water injection infront of it for 10,000k's and I'll go ahead and not. Then we'll compare at the end, sound like a plan?
    Facebook | LinkedIn
    i did this with my old turbo+carbi setup. Isn't ideal as you have relatively large droplets of water hitting compressor wheel. If you can solve the atomisation issue then do-able, but post-turbo is better.
    A friend of mine does this with great results, like you have pointed out already though the water needs to be a very fine mist. If it hits the comp in a stream then it can actually cut the comp wheel.
    You can add methylated spirits to the water to assist with the atomisation.
    I'm pretty sure that the kit used in the article had very good atomisation...
    why not just do it post turbo and avoid the chance of stuffing your comp wheel? Is it not just the placement of the nozzle which would have to be changed?
    QUICKEST 1JZ'S IN OZ
    Is there any actual advantage of having the spray kit pre turbo?
    Pumping against the compressed air will be a tad more difficult, although no more than running a pressure line behind the pump as a compensation.
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    Quote Originally Posted by chris davey
    but then you'd need a seperate pump, you couldn't just use boost pressure
    I have a Crown
    Agreed, that's what I read too
    Facebook | LinkedIn
    my kit just used a fine spray head just at the front of the carbi spraying directly down the throat (CD175 stromberg). used a windscreen washer pump, triggered with a 5psi hobbs switch and a 50:50 mix of water:methanol
    Now that i have an intercooler and proper fuel/spark management, i've not needed it.
    Feb 2007
    Wink Re: water injection pre turbo
    from what i can understand ,
    using a pumpless system, there are very few moving parts,less things to clog up, dont get problems when you use methanol but a big one for me is when you see a draw thru carby setup, you see some that acually frost up the pre turbo area and this is what i would see as the big advantage as when you have the water/fuel under vacuum it has an adverse effect on the air as it seems to alter the desity or something, i remember reading some of the supercharged guys commenting that the boost rose slightly, a turbo car would not see this but it may increase the efficientcy of the turbo somehow, there is a thread in another forum if anyone wants to read it i can dig up the link...
    i have been recomeded tho use metho or methanol to reduce the chance of water freezing under vacuum( i dont realy belive it tho) i would like to use some methanol for the fuel advantage but
    from what i have been told , one of the better post turbo systems is the aquamist, and one guy i know that uses it swears by it .. i think the only drama is the cost factor...
    im thinkin of goin this way mainly cause its cheap and reliable, its very dificult to use those two words together usually cheap and sh*& or reliable and expensive.I would like to see if anyone is using this method.
    rob
    Feb 2007
    Quote Originally Posted by YelloRolla
    i have heard the same...
    they do use water to cut steel i suppose.
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 08:10 AM
  2. I have a Hi flowed CT26 and want to upgrade to another turbo..
    By tai_180sx in forum Tech and Conversions
    Last Post: 14-12-2006, 05:35 PM
  3. Water injection vs Intercooler
    By Gibbon in forum Tech and Conversions
    Last Post: 21-10-2006, 05:57 PM
  4. 4agte turbo water feed/return
    Last Post: 02-10-2006, 04:02 AM
