As set of adjustable top arms will help the clearance to the floor a little. They will also help to bring the pinion angle down a little, which in turn will increase traction.
This is given that the bracket on the diff are in the same spot as the standard diff.
... 11's soon
I beleive the new ones they stock are too long and require cutting down. The lower arms with the Heim joints were made by Linden at Roadrunner Fabrications (The Real Roadrunner) The lower arms also run the KE70 Corolla bushes at the chassis end instead of the Celica bushes as they are the same width but a smaller diametre to further remove the amount of give in the urethane. All I had to do was change the centre bolt sleeve to the 14mm sleave instead of the KE70 12mm sleave. This required no mods to the bush itself as they interchange. They use the SuperPro Bushes. While these were out I had Linden reinforce the mounts on the body and the diff by welding a 2mm washer on the outside of each bolt hole to prevent the holes from elongating under load at launch.
