Results 1 to 13 of 13
Thread: how to test a speed cut defender without driving on the street?
    Default how to test a speed cut defender without driving on the street?
    so yeah, how do?
    i was thinking jack up the back end and taking off the wheels but i think the shafts would still hang down too much for a high speed run (180km.h+) and put too much stress on the uni joints.
    other option would be to remove the tailshaft with the back end jacked up to stop fluid leaking from the tranny.
    has anyone done anything like this? i definately dont want to do this on the street. (anyone know some good straight streches of 'private road' in adelaide? preferably north east?)
    the only really sensible option would be to go to the drags but being in adelaide this is not likely which is suprising considering how much money goes into hosting and promoting motorsports in this state.
    Default Re: how to test a speed cut defender without driving on the street?
    Pay $50 for a dyno run.
    If in doubt power out
    Jack up the rear of the car, remove wheels and then tie suspension arms up to the body (ie get rid of wheel droop?). Still, not a fan of having a wheel rotating at 180+km/h with the car just sitting on chassis stands (makes me think of the end of Ferris Bueller's Day Off), dyno would be much better option
    I once accidently used a UZS131 Crown speedo sensor, which is 20pulse/rev (most are only 4pulse/rev).
    The speedo went off the charts before I left the driveway.
    Otherwise, just use a drill...
    May 2010
    Moscow
    Don't remove tailshaft, you'll lose trans fluid then
    Put bricks under susp. arms to retain normal ride height and prevent u-joint stressing
    keep in mind that if your car runs open diff, the whole procedure would stress it, too
    in every other aspect running 180kph on bricks isn't more dangerous than doing it on road
    Agree with peewee... put a drill to the speedo drive gear
    May 2012
    If you want to be a smart-ass geek about it, you can always build or buy a frequency generator. Hook it up to the speed sender output and dial the speed up while you drive. That way you get to watch the speed and have some load on the engine when it hits the cut (it may not cut fuel at idle revs for safety reasons).
    But one of those sets you back about as much as a dyno run. And most dynos can get to 200km/h, so as long as your car has the limiter at 180, you're set.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    I've done the old jack it up trick a couple times not a good idea it shakes around heaps and is a disaster waiting to happen
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Oct 2009
    Yeah I wouldn't want to do 180 on stands lol
    Unbolt the half shafts on the diff?
    Tasmania
    Just take the tailshaft out and put a dummy yolk in an way you go.Did this today with a Celica to see if the speedo was working after engine swap 140k+ no probs no vibrations no danger of car shooting off jack stands.
    Cheers Brett.
    oregon
    Quote Originally Posted by RONA View Post
    THIS /\
    now to lengthen this post to over 10 charachters..........
    Junior Member Conversion King
    May 2010
    I tried to avoid posting before as it's not exactly helpful (plus the dyno post is EXACTLY what you are after).
    But.
    Why are you worrying about a speed cut defender if you have no use for it? I guess if you are prepping for an upcoming track day then it might be a viable excuse, but it just seems weird to me you are installing one with no way of testing it. Please correct me if I'm wrong.
    yes its for use at the drags; i always hit speed cut before the finish line.
    its hard to find a dyno day on the cheap but i am going to pay full price for a dyno run to make sure fuel is ok and will get the speed cut checked there as well.
    i have done a few dynbo runs before and never hit speed cut so im guessing they will have to do a special run to reach 180.
    i liked the drill idea (although i would have to be revving the engine at the same time i guess) and also taking the side shafts off.
    thanks for the input guise
  1. Jaycar Fuel Cut Defender - need a test vehicle
    Last Post: 14-10-2007, 07:32 PM
  2. Pivot speed meter/speed cut defender
    By 2JZR31 in forum Tech and Conversions
    Last Post: 04-07-2006, 10:50 PM
