Results 1 to 5 of 5
Thread: Turbo machining
    Default Turbo machining
    Hey all,
    Does anyone in Perth know someone that would machine some turbo housings in Perth for next to nix? I've got my Blitz BAG turbos on my 1GGTE which are based off some Gen2 CT12's. As such, they have the smaller feed pipes.
    I've like to experiment running the larger Gen3 inlet pipes, and while I could just bolt them on, I can't help but think it'd be a good idea to actually taper the inlet on the compressor housings to port match them.
    Of course, I don't want to spend much money to test out my theory.
    Any suggestions?
    Nathan
    Forum Sponsor Conversion King
    Default Re: Turbo machining
    anyone with a lathe should be able to do this for you , first mark the cover at the tip of the inducer ( only machine forward of the mark ) then just remove comp covers and get them turnd . if they use a three jaw it should hold the comp cover on the inside face where the back plate sits.
    about $40ea should cover it.
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    If I was a little closer, I would do them for you for nix.
    Good luck anyway, as been mentioned already, and person competent on a lathe should be able to do it.
    Can you remove the comp covers with out remove the turbos at all?
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
    By the time I manage to pull the compressor covers I may as well have pulled the turbos off
    perth
    grant from performanz does all that shit
    hes on radium street off welshpool road
    Last Post: 03-05-2009, 06:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
