I just did a yellowpages.com.au search and came up with two.
Bonneville Automotive Pty Ltd
17 Phillips Rd Kogarah NSW 2217
ph: (02) 9553 4708 Motor Engineers & Repairers
Edit: called both, deleted the wrong one.
Cost quoted today $300 + postage.
any1 got da number for the bonnyvile automotive or wateva that place is called and were this place is as live in albany=400km from perth.
thanks a heap enchanter![]()
No, sorry. MX83 to JZX81 does not always work. The A/C top and lines on the 7M are taller and foul the 2JZ power steering pump when on top of a 2JZ A/C compressor. The Aristo 2JZ compressor is large diameter so there may be smaller diameter compressors on the 1JZs where this will work but can't confirm. (The 2JZ "looked" like it would work).Originally Posted by CrUZida
On at least some 1UZs the 7M A/C lines will bolt up directly to the 1UZ compressor top.
Mos.
my front cut waz originally manual but the box didnt come with my frontclip but i got a auto with computer from a soarer with a 1jz.. will it still work ok even tho the 1jz in my clip waz manual and prob ran from my ecu? im a noOb!!![]()
ok so we are talking bout the digi dash? im going 1jz-gte, how does the tacho converter go on? does it just plug into the back of the stock instrument cluster then the 1j wires go into that?
There are two plugs that go into the back of the original ecu, one is for the engine loom, the other is for the body loom. The body loom plug stays with the car after an engine swap and has a few good pins on it for the use of hooking up a tacho.
Have a look at my recently made thread about howto build a convertor for more info if you haven't already![]()
1JZ:Originally Posted by JZA61
Output of ignitor goes to tacho convertor. (trace back from IG in the diagnostic plastic box on the engine)...
Tacho Convertor:
Power to tacho convertor
Ground to tacho convertor
Input from 1JZ ECU (IG)
Output to MA61 Dash
MA61 Dash:
Output of tacho convertor -> Dash tacho input
Easy
You have to wire it in yourself...it doesn't just plug in
cheers wilboOriginally Posted by wilbo666
hey guys, im a little lost, haha. i have a gz10 with a 1ggeu (auto), and ive got a 1j and box (auto),and whole wiring loom, does everything on that list apply to me? just some things dont sounds right?? any help would be great![]()
All mechanical stuff will be 99% identical.
Electrical stuff will be 90% identical with a few small differences.
Can i ask, is the gearbox kept in the same position because its easy or it does not need moving back?
Originally Posted by skiddz
Hey guys I was trying to get in touch with Bonneville to get more info on the 1j mounts for my ma61 . Can anyone tell me if this info is still correct ? 2 days calling with either a busy signal or an operator saying "sorry your call cannot blah blah blah !!
it's an expensive bit of steel but with most other options being solid mount I would like to know just how these worked from someone who has them and if they used the extra mounting holes in the block for a little more room up front ? Just some noob questions and search came up with a little info but no first hand experiance from an owner on install and fitment issues. Thanks for any help the JDM gods can provide . I can make them but I would rather buy the mounts and be done with it . The measuring and fitting and remeasuring just gives me a headache so I would like to make sure it's done right the first time.
Bruce
82 Ma61 1JZ/R154 HKS Twins
94 JZA80 V160 S475R (sold)
94 JZA80 V160 T51R KAI CDN. Spec
Thats the last number I had for them, but you'll need to dial +612 9553 4708
Thanks thats what I was dialing but I needed to add 0116 ...I'm so far away they had to add a couple more numbers ..I just spoke with Ryan and he gave me all the info I needed. Mounts are on the way . He also said he's sold around 60 sets now
1j madness can this be true ?
Bruce
